TXDTR #8 Forum for the Texas chapter #8
North Texas DTR #8 November GTG
Old Oct 26, 2007 | 07:16 AM
fade94's Avatar
RJ- Thanks for the info. Questions for you:
What is a manual boost controller and where can I get one?
Who makes the 62/12 and also, where can I get one?
THANKS !
Old Oct 26, 2007 | 07:17 AM
RowJ's Avatar
Tyler suggested the 10th for a GTG at Brians. Works for me. Anyone else?
Seems we always have an install or two to do at the GTG's.... so an indoor area would be my first choice!
RJ
Old Oct 26, 2007 | 07:21 AM
RowJ's Avatar
Wayne,
MBC's .....HERE
Don't need anything fancy.... I have used and like the BC-03 from JoeP.
PhatShaft 62/12 Turbo, from Industrial Injection .... HERE
RJ
Old Oct 26, 2007 | 07:38 AM
fade94's Avatar
The industrial injections site is down right now for the turbo. I did find an HTB 62/12. How are they?
Old Oct 26, 2007 | 07:55 AM
RowJ's Avatar
The site opened for me??? Try this... http://www.industrialinjection.com/id34.html
Have heard good things about HTT turbos, just don't know anyone, first hand, that has one.
Tyler has the PS62/12 and loves it for fast spool up (more important on an auto than a manual).
I'm sure either one would do you well. They are definately the top two out there now, IMO.
RJ
Old Oct 26, 2007 | 08:45 AM
AggieJustin's Avatar
RJ
I'm out for the 10th, got a wedding in McKinney that day (not mine). Actually, the only weekend in Nov that would work for me would be the 17th.
Used HX-35 would be economical and effective
I happen to know where there is a used HX35 if you wanted to try it out.
Old Oct 26, 2007 | 09:05 AM
Diesel-Dan's Avatar
RJ
Ryan Woods has an HTT Turbo.....has lots of good things to say....
Old Oct 26, 2007 | 09:17 AM
fade94's Avatar
Good, bad??
Old Oct 26, 2007 | 09:18 AM
fade94's Avatar
Will it work with stock downpipe?
Old Oct 26, 2007 | 10:21 AM
Diesel-Dan's Avatar
Converting from an HY-35 to and HX-35 is not just a 100% bolt up job (WELL as far as the turbo goes...yes....BUT....) The engine coolant lines under/around the exhaust manifold are different and due to the way the waistgate is positioned on the HX...it will interfere with the lines on the auto engines. I believe you will also need the hard coolant lines off a standard tranny engine or just use some heater hose to reroute them.
Ryan loves his HTB2 HT turbo....it has a 14cm housing i believe.....had it for about a year now.
The HX and HY use the same downpipe...so you are good there......
Old Oct 26, 2007 | 02:46 PM
fade94's Avatar
Hey, anybody know where I can get the type of plastic tubing that is used for the helper air bags? I want to move my switch and gauge and need to get more tubing.
Old Oct 26, 2007 | 02:49 PM
bnold's Avatar
First place that came to mind...
http://www.coolingmist.com/detailmain.aspx?pid=1407
Old Oct 26, 2007 | 03:10 PM
fade94's Avatar
As usual, you da man.
However, I looked all over that sight and could NOT find an oblong switch. They were all round?
Old Oct 26, 2007 | 03:33 PM
Diesel-Dan's Avatar
UM....you can also check out the place in Denton at 35 and 288. Inland Truck parts. I would almost bet you they have that line in-stock.
Old Oct 27, 2007 | 12:52 PM
hotdram's Avatar
Contrary to popular belief, I am not dead and have not been ignoring you guys. Just been busy. Went home to PA last weekend and started my new position 2 months ago. I don't log on from work anymore, they actually keep me busy and expect me to work It makes the days go by really fast, which is nice.
I am up for a GTG in Nov., don't care what weekend, just let me know.
Let the modding begin, truck is paid off
~Rob
