Wiring for trailer breaks on an '05
Old Mar 23, 2006 | 01:56 PM
Igor's Avatar
Hey guys,
Just wondering if my '05 1 ton comes with a "wire" or a "port" under the dash where I can hook up a controler or whatever I need to wire up electric breaks on a flat deck car hauler trailer?
And if so, which readily available aftermarket controler do you guys recommend.
I might have to do this in a harry, as I plan on buying a new trailer on my way home from work, which is 700 miles from home.
Thanks guys,
Igor.
Old Mar 23, 2006 | 02:28 PM
SolarYellow05's Avatar
Yours should have come with a pigtail that plugs in under the dash near the firewall. My pigtail was in the glove box. If yours does not have one, you should be able to get one from your local dealer for around $20. Prodigy is a very nice brake controller.
Old Mar 23, 2006 | 04:55 PM
rammtuff's Avatar
I think if you have the trailer tow package you get the BRAKE control pigtail.
PM fiver bob for controllers. He knows it all.
Old Mar 24, 2006 | 10:35 AM
hubmonkey's Avatar
The pigtail I got from Dodge was under my back seat with the Front Brack for plates.
I use the Prodigy, it is a very good controller. One thing also is I just forked out the 12 bucks extra to get the Dodge Harness with the controller. No spicing the poor pigtail from dodge... Just click click and you are done.
Got my prodigy from Rvwholesalers.net for 89 bucks... I could not even come close to that price local.
Hub
Old Mar 24, 2006 | 03:11 PM
dodgeguy71's Avatar
big blue connector under the drivers dash, towards the left side, should be around a large wiring connector, you should have had a pigtail when bought, but if yours is like mine, it was taken out during the inspection so I could go back later and buy it back from them. Real easy, plug it in, wire it to your box.....vroommmmm!!! Is it already wired out the rear?? I'm using a cheap box, bought 4.5 years ago....still working well, have heard good things about tecumseh, but to rich for my blood when the inexpensive one has done the job so well. just my .02
Old Mar 24, 2006 | 03:37 PM
runamuk's Avatar
Igor,
Do a search on the subject someone has a picture up of exactly were the dern thing is! I hunted and hunted then I searched this site and found the answer in 5 minutes.
Rick
Old Mar 25, 2006 | 01:44 AM
SuperGewl's Avatar
Yes ther is one however if your truck did NOT come with the TT package then the blue brake control wire is NOT run. Look under the dash just up above the parking brake. behind the wireing there is a blue connector, that is where you plug into. Check your Marooney sticker to see if yours came with the TT Package or have your dealer do a VIN check and print it out for you.
apache
Apr 4, 2005 12:30 AM
TexasHardcore
Sep 26, 2004 08:05 PM
Palmetto_kid
Apr 5, 2004 10:12 AM
dieselnewbie
Mar 23, 2004 04:46 PM
Mostwanted
Sep 17, 2003 09:36 AM
