What's the standard height for a gooseneck trailer coupler
Old Feb 25, 2010 | 01:02 AM
DL1221's Avatar
I want to buy a gooseneck but I think my flatbed may be too tall. The gooseneck ball on my bed is 44" from the ground.
I don't know what the standard height for a gooseneck trailer coupler is, but I saw on a catalog from PJ Trailers that their height is adjustable from 32 13/16 to 40 13/16 inches. So this means that my truck's ball is about 3" taller than it needs to be, don't know if this will be a problem or not?
Does anybody else know if all goosenecks are adjustable, like these, or what the standard height is?
Old Feb 25, 2010 | 06:04 AM
Load Hauler 04's Avatar
Most gooseneck hitches on trailers are adjustable. You can run it that high but the front end of the trailer will be a little high. Is you ball attached to the bed or the frame?
Old Feb 25, 2010 | 06:25 AM
Was just outside feeding and mine on my trucks range from 37" to 38 1/2 "
Old Feb 25, 2010 | 02:32 PM
DL1221's Avatar
My ball is welded to the flatbed, which is bolted to the frame with a heavy steel plates, no wood. It's one of those flatbeds that has a compartment with a lid that opens up to reveal the ball inside. It was made to pull a gooseneck, so I'm sure it will hold. So at some point I'll switch back to stock tires, and that lower the truck a few inches.
Thanks for the info.
Old Mar 5, 2010 | 03:31 PM
xyzer's Avatar
Older gooseneck trailers were lower than the newer trailers.....reason.....newer trucks are taller...so how it fits depends on the trailer year.
Newblue
Dec 13, 2010 09:19 AM
LongRanger
Feb 2, 2010 10:03 AM
katoby
Oct 24, 2009 06:41 AM
TxnBorn88
Aug 16, 2006 07:52 AM
mestdagh
May 7, 2005 07:23 PM
