what to look for
what to look for
I was thinking latley of getting an older 5th wheel, i want something pretty big but cheaper cause i will be putting dirtbikes in it and to use when friends go out tenting. what do i need to watch for in older 5th wheels are brakes and suspension a big deal, or is it stuff like plumbing? what are must haves or styles things to look for. Im sorry for posting this question cause i know i should go look on my own but about how big could i pull with my truck, 1998 4x4 quad cab, long box, 2500. any imput is great thanks
Yeah, I have dutch 5th wheel, and that camper gets more water leaks every year than my garden hose in the drive way when it gets ran over. Also, if you notice water damage of any kind on the ceilings then know that the 2x4 in the walls will be damaged.
You get what you pay for (hopefully).
1) Check the frame, hitch area, axles for rust, etc. Got to have a solid platform or nothing else matters.
2) When you get it, pull the wheels and repack the bearings. Check the brakes. You'll want working brakes on both axles. Make sure the lights are working.
3) The integrity of the walls and roof - leaks, rot, etc. Roofs can be re-sealed, bad sections of floor replaced.
4) Systems: Plumbing, fresh water, black water, grey water, LP systems, any furnace or A/C, fridge, any on-board battery, any 30/50amp connector, any generator - depends on what you have and what you are going to use.
Be careful as to size and weight with a 2500. 25' bumper pulls can weigh in around 4-5,000#, bigger = more weight.
Hope this helps. Happy Camping !
JKM
Dec 12, 2012 12:09 AM
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
