Wells Cargo 24 Beater Trailer
Old Feb 17, 2008 | 06:21 PM
  #31
PsychoRallye's Avatar
Originally Posted by P.J
Definitely electric drums, you wouldn't want surge brakes on a trailer like that anyway.
What size are the rims and what weight rating are the tires?
The plate on the trailer says to use 15X5/38.1X12.7 with ST205/75R15 tires. However, I looked at the installed stuff and what is on there are ST225/75R15 D range tires. I should note, that when I eyeballed it with a tape measure, the 6 lug rims appear to be 5.5" to the lug on the opposite side. Does that sound right?
The dust caps on the end of the axles said "Dexter EZ Lube" but nothing else. I didn't tear into them today... I'm still replacing the decking (it was pretty bad) and I saw a minor amount of rust I want to weld up some gussets to to make sure I have no issues (on some of the vertical spars that support the sides of the trailer and the top) -- the ones right at the back of course!
Guess I'll pull a wheel tomorrow to get brake & bearing sizes. Where do I measure on the bearings, the ID or OD ? Can I do it with the races on or do I have to remove the bearings from the races?
Old Feb 17, 2008 | 10:16 PM
  #32
torquefan's Avatar
Usually I remove the bearings and races and find that the part numbers are still legible. If not, I clean them off and take them to let my trusty partsman measure them to match them up. Hopefully yours are still useable, unless they have been neglected.
BUCKEYE4X4
16
Jun 20, 2007 06:03 PM
jeepsuck
May 14, 2006 03:22 PM
diesel_kid
Jan 7, 2005 10:05 AM
hellotbone
Nov 4, 2003 08:35 PM
bigredbrick
Jun 12, 2003 12:00 AM
