?Use of EB when towing fifth-wheel?
I am very new at this. When using the EB and down shifting on a steep down hill run, how high is it safe to let the RPMs go?
Is it easy to down shift and over speed the engine?
jr
jr
The directions that came with mine say that for optimum braking performance it is necessary to keep engine RPM as high as possible, but do not exceed 3200 RPM (ISB).
I don't run mine that high, though.
Originally posted by falcondan9570
bad castings and causing fires...
Most rumors cite a leak at the junction with the turbo. First time I have heard the bad casting idea.
The latest I got from the dealer was that they were to return all EB stock and an 'improved' version was to be available in December. The dealer had no information as to why.
jr
I have a PAC Brake, with an older automatic you also need a way to Lock the TC. Running both a Ram and a PSD I ate pads and rotors real regular before the EB's were installed. Both engines having over 300k on them not worried bout warranty. Personally. . .for diesel's haulin much I think an EB ought to be the law. JMHO
Cheers,
Steve J
Cheers,
Steve J
Here is a link to Jacobs driving instructions for their Ebrake:
http://www.jakebrake.com/service/pdf2/032491A.pdf
In a nutshell Jacobs says:
"To obtain the optimum braking performance from the Jacobs Exhaust Brake it is necessary to keep the engine RPM as high as possible, but not to exceed 3200 RPM. Select a gear that will cause the engine to operate as near to 3200 RPM as driving conditions permit."
FYI, 3200 RPM is redline for the 3rd Gen.
As near to 3200 as you can but not over? I am new at the diesel truch thing and at 3000 it seems as though engine parts will soon be coming through the hood.
jr
ultramag
May 28, 2010 11:05 AM
checkster
Mar 28, 2008 04:25 PM
kninja
Nov 29, 2005 05:53 PM
