Trailer brake lockup
Old Oct 28, 2008 | 08:11 AM
high bid's Avatar
I have a tandem axle trailer w/single hydraulic drum brakes. I completely rebuilt the brakes last spring....cyclinders, pads and lines. After stopping, one side won't release and keeps tension. When driving, I don't notice it until smoke begins to pour from the wheel area. I have to stop and open the bleeder valve to get the cyclinder to release pressure. When installing everything, I gravity bled the system, tested it all and it worked fine for awhile but I'm not sure what could keep causing this issue. Any ideas would be appreciated.
Old Oct 28, 2008 | 10:07 AM
Dartsport's Avatar
Possible bad brake hose at that wheel. Sometimes they collapse on the inside, holding the pressure on the brakes.
Old Oct 28, 2008 | 10:45 AM
high bid's Avatar
The thing is, they're metal lines directly to the cyclinders, except prior to the t-fitting where it transitions to the axle. Wouldn't both sides be holding pressure?
Old Oct 28, 2008 | 11:43 AM
whitebuffalo's Avatar
debris in the sticking wheel cylinder?
Old Oct 28, 2008 | 12:48 PM
high bid's Avatar
I'm guessing in order to determine the cause, I'll have to disassemble all of it. pita.
Angry Johnny
Aug 23, 2016 05:01 PM
93dieselZak
Jun 16, 2011 06:10 PM
JQmile
Sep 15, 2010 10:43 PM
Cowboy_Customs
May 6, 2008 09:39 AM
Tackdriver
Dec 19, 2002 06:10 AM
