Trailer brake controller help!!!
Old Dec 5, 2008 | 10:33 PM
bluechrome's Avatar
My controller Flashes OL while I'm on the brakes. I have zero trailer brakes. Any input?
Old Dec 5, 2008 | 10:57 PM
Ronco95's Avatar
Sounds like a wiring short to ground. Check your trailer pigtail with a DVM and see if the brake wire shows some meaningful resistance or very low resistance.
WestTN's Avatar
Which controller do you have?
Old Dec 5, 2008 | 11:11 PM
bluechrome's Avatar
Drawtight activater II
Old Dec 6, 2008 | 09:52 AM
2006Mega's Avatar
i thought OL ment open line?
Old Dec 6, 2008 | 06:39 PM
MRFD715's Avatar
I've got the same controller and it's been giving me all sorts of fits and I've rewired everything and had it checked by people that do that sort of thing for a living, they don't know why it's not working. I'm looking for a new controller.
Old Dec 6, 2008 | 09:31 PM
edcasey's Avatar
I've been a master certified RV Tech for 15 years. I highly recommend the Tekonsha Prodigy brake controller. Best brake controller available. Inertial controlled, auto level, digital display, good for up to 4 axles and you can buy an electrical adapter that plugs directly into the brake controller and the jack under your dash. No splicing necessary.
http://www.tekonsha.com/prodig.html
http://www.tekonsha.com/tbsabrakeconwireharn.html
Old Dec 6, 2008 | 10:20 PM
Spooler's Avatar
I got a free drawtite you could have if you were close. Forget the Prodigy. Go for a Maxbrake or a BrakeSmart. Best money I ever spent.
Old Dec 7, 2008 | 05:04 PM
SlowJeep's Avatar
Originally Posted by st.rodder2
I had the same problem with my prodigy - OL would flash at time and have no trailer brakes. Found the wire that runs thru the front axle tube broke inside the casing. Replaced the wires to the outside of the axle tubes. Solve all problems.
I had the same problem.
The brake wires running through the axle tube actually melted together.
Old Dec 17, 2008 | 12:41 PM
2006Mega's Avatar
from some of the other sites i go to that seems to be a very common issue.
tincan
Oct 19, 2007 10:50 AM
0425004x4
Dec 14, 2005 01:58 PM
Dieselhead
Nov 15, 2003 04:53 AM
PADZZ
Mar 18, 2003 09:47 AM
doodah
Jan 7, 2003 08:30 PM
