Trailer ball info.
I found a 12,000lb rated 2 5/16" trailer ball that I wanted to buy, but was told it is for pintle-use only. The only visible difference I saw was that it had a nylon lock-nut instead of a steel lock-washer and conventional nut. I have a 7,000lb rated open car trailer now but eventually plan to tow a 12,000-rated enclosed trailer. Is the "nut" the only difference?
Would appreciate any info on these applications.
From: Used to be missoula, montana: Now in Sonoma County California
the length of the ball shank (correct word?) the non-threaded and threaded surface below the ball is longer. the pintle provides more surface area for side loading of the ball's shaft.
now if that makes any sense
i think that the mating sufface at the base of the ball has less diameter also because it uses shank side loading and not the sufface of the stinger ?????
I would like nothing more than to have a goosneck! But I already have a 26' tag that I haven't hauled anything in yet. Still working on finishing the interior. But even with my race car and support stuff, I'm pretty sure that the actual weight will be under 10,000lbs. It will be awhile before I recover from the recent truck purchase.
Yes that ball is for pintle/ball combo hitches. The shank is shorter and the ball is designed to mate with the hitch. Buyers makes a nice pintle/ball combo hitch. You should be able to find a 2 5/16" ball for a standard receiver hitch without too much diffculty. Also I suggest sticking to Made in the USA hitch componets.
firebill1720
20
Mar 5, 2010 09:23 AM
Wulzcat
Dec 22, 2009 02:28 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
