towing with 315's
Old May 24, 2006 | 07:20 AM
mooseman's Avatar
Originally Posted by d0dg301
I just changed out my 3.55's for 4.10's. The 3.55's would pull my 10K toy hauler ok but the long hills I did not like. My temps shot up quick and I could tell it was hard on the truck. I will get to try out the new 4.10's this weekend so i'll let you know what I think of them. Will see if it was money well spent
Keep me posted. Im curious.
Thanks Mooseman
Old May 24, 2006 | 09:24 AM
y22man's Avatar
Mooseman,
If your pictures are any indication as to where you are having trouble. Looks like you go somewhere by Strawberry or Spanish Fork canyon. I too have troubles on dirt mountan roads. I tow about 12K, guessing, when I go. Since purchasing the 5er I no longer go up Mayfield canyon or up to Skyline drive anymore. The reason being how hot the tranny gets and how long it takes me due to I have to stop and cool the tranny down. This is because I can not run fast enough to get the tourqe converter locked. I am hoping to get a fully built tranny soon so I can lock up sooner and go camping there again.
On a side note, when I go to Fish lake with my fathers boat 6000 lbs if I stop due to traffic on the exit by the lodge. I have to put it in 4 low to get the boat moving again due to the steep incline.
Old May 24, 2006 | 01:37 PM
gunracer1's Avatar
it sounds to me that your converter may be too tight.
Old May 27, 2006 | 10:25 PM
mooseman's Avatar
Originally Posted by y22man
Mooseman,
The pics. are in Logan canyon by the Tony Grove area. Not a very steep canyon road but alot of sharp corners to slow down for.
Old May 27, 2006 | 10:37 PM
mooseman's Avatar
Its defiantly on the tight side but after installing the 410's today and after a test drive tonight that converter don't seem to tight any more. There is almost 0 lag out of the hole now. Much Much better set up for me. I am very pleased with the end results.
Mooseman
Old May 28, 2006 | 02:04 PM
displacedtexan's Avatar
Good to hear that you got it working more to your liking. And to know that you didn't have to shell out $1000 hoping the re-gear would do what you wanted...
Old May 29, 2006 | 12:36 PM
J BODY's Avatar
My truck was born with 4.10's and I swapped out to the 3.55. Key factor for me is running the stock size tire and my trailer at it's heaviest is probably around 9k. I didn't like the cruising speed rpm with the 4.10's. At freeway speeds the rpms would be too high and the fuel economy suffered. With the 3.55 I can cruise 75 and keep it under 2k rpms and pull 18-19mpg. My truck wouldn't do that with the 4.10's thats for sure. I'm sure if I go to a heavier trailer someday I'll probably wish I had the 4.10's back, but for right now I've got the best of both worlds. Good towing power, good cruising economy.
Old May 29, 2006 | 03:57 PM
mooseman's Avatar
Running 315's with the 410's @75 Im right at 2050 rpm. Im sure if I ever go back to stock tire size I will be going back to 355's but for the big rubbers the 410's are the perfect combo for me.
Mooseman
Old May 30, 2006 | 09:33 PM
d0dg301's Avatar
Thanks Mooseman
Got back from a 600 mi. trip with the 4.10's and the 315's. Very nice. Had no problems at all. My truck worked just like one would expect there truck to perform. Cruised down the freeway just fine and climbed the narrow whindy hills like a dream.
Old May 31, 2006 | 08:31 PM
mooseman's Avatar
Thats good to hear. I sure love mine so far. Im dieing to see the diff. while towing but I was told to put atleast 500 mi. on before I tow heavy so Ill have to wait a couple weeks.
Mooseman
Old Jun 20, 2006 | 01:09 PM
ridofpwrstroke's Avatar
You will be very happy. I only wished I would have gotten an underdrive auxillery trans. Now cruising down the highway empty i run 2100 at 70. I miss the 2k running at 80. But I regeared for towing. Definately better.
classicpuller
39
Dec 18, 2009 01:19 PM
KillerBee
Nov 16, 2007 05:12 PM
turbo dreams
Aug 19, 2005 11:05 PM
rjordan
Sep 27, 2004 09:25 AM
popeye
May 25, 2003 12:25 PM
