Tow Hooks - Correct Part # ??
Old Feb 20, 2006 | 08:51 PM
biglar's Avatar
I picked up my new towhooks at the Chrysler dealer the other day, after taking the advice here on the forum. Now I have more questions...... The instructions diagrams don't match my truck, and these hooks are (apparently) designed to bolt on the end of a rectangular tube frame. That's fine, except that the front end of the frame where the bumper mounts are is a C section, not a box. The inside of the frame is open, I guess for access to the bumper bolts. Also, these hooks and attachment plates are huge. It looks like I'd have to remove my bumper lights. Any ideas or experiences with these ?? The part number of the hooks they got for me is: 82207917. I want to be real sure these will work before I start cutting that front end of my truck. Thanks all
Lar.
Old Feb 21, 2006 | 02:25 PM
rfcom's Avatar
I don't recall the part number, but I know for a fact there is no cutting or drilling involved in installing these things. They also have no effect on your bumper lights. The only thing you do have to cut is the holes in the air dam, if you have one. If it helps, I'll try to find some pics of my install.
Jim
Old Feb 21, 2006 | 07:08 PM
biglar's Avatar
Jim
I'd sure appreciate some pictures if you can send them. Send to: biglar@gogittum.com , and put the subject line in capitals. Also, any other words of wisdom you could share would be welcome. I can only see where one side of the mount could be bolted on.
Lar.
Old Feb 21, 2006 | 07:37 PM
rfcom's Avatar
OK, pic is approved.
https://www.dieseltruckresource.com/...hp?photo=16496
The mounting brackets bolt to the frame where the bumper bolts up and also to the cross member between frame rails.
Disregard the bottom bracket, that's for mounting the grille guard.
The kit I got is part number 82204881.
Jim
Old Feb 21, 2006 | 11:10 PM
biglar's Avatar
Jim
Nope. Ain't a gonna work. Yours looks like a big hook laid on its' side and mounted under the frame. Mine is like a big loop or ring with a prong in the middle. My setup is totally different from yours, and the pieces in my kit don't even match the pictures in the cheesy pictorial instruction sheet. Thanks very much for your help - this kit is going back to the dealer tomorrow.
Lar.
Old Feb 22, 2006 | 06:03 AM
CTD NUT's Avatar
From what you describe, it sounds like you have a 3rd gen tow hook kit.....it definitely won't work on a 2nd gen......return the kit.
Old Feb 22, 2006 | 03:32 PM
biglar's Avatar
Yup, took it back just now, and it's for 3rd gen. He's having a real tough time finding a p.n., so I'm going to call him and ask him to check the p.n. that Jim gave me.
Lar.
Old Feb 22, 2006 | 06:51 PM
biglar's Avatar
Interesting. I called the dealer, and the parts guy ran Jim's number and said it's only for '99-'01 trucks. Says it won't work with my '02. ????? He's going to call the factory tomorrow and let me know what he finds out. All his books jump from '01 to '03. Guess mine is an orphan.
Lar.
Old Feb 23, 2006 | 02:44 PM
rfcom's Avatar
He must be looking up numbers for a 1500. They switched to the 3G body style in 02 but the 2500 and 3500 switched in 03. The part number is right and it's definitely the right parts for my '02 2500 4x4. I had a similar problem with the rear wheel well liners. Parts guys don't always know everything.
Jim
Old Feb 23, 2006 | 09:11 PM
biglar's Avatar
Yup. Checked with him today, after he'd called the factory, and Jim's part no. is correct. My new hooks will be in tomorrow.
Lar.
pappygtb
Mar 4, 2003 10:36 PM
4406PACK
Jan 27, 2003 08:57 AM
doug
13
Dec 10, 2002 08:48 AM
j
Oct 22, 2002 08:47 PM
j
Oct 22, 2002 08:39 PM
