Suspension Question
Old Jul 19, 2007 | 10:20 AM
jp39bfd's Avatar
Question Suspension Question
I have an 06 2500 QC Shortbed, as my sig says, I believe as far as 5th wheel towing max pin weight on stock setup is about 1800lbs. I was looking to pull a little heavier camper w/about 2100-2200lb pin weight. Any suggestions on what to do with the suspension?? Thanks for any help you can give me.
Old Jul 19, 2007 | 02:26 PM
LOGAN's Avatar
Muted User
E-range tires and a set of airbags is a good start.
Old Jul 19, 2007 | 02:29 PM
rustyshakelford's Avatar
riderite 2299 and some good tires like logan said!
brett
Old Jul 24, 2007 | 11:16 PM
stumpjumper's Avatar
i have 2160 pounds hitch weight and have towed a few thousand miles that way. i had the airlift air bags and took them off. it looks like the brackets that mount the bags to the axle take away 2 inches of suspension travel. the suspension travel is very important because i go out to the desert alot for racing. before i leveled my truck it would sit level with the fifth hooked up. now it sits about 1-1 1/2 inches lower in the back. and rides great...
mtnman006
24
Sep 8, 2009 03:14 PM
diesel03
25
Aug 4, 2005 08:35 AM
Pike
Sep 26, 2004 01:54 PM
gregway
Apr 13, 2004 02:40 PM
banzaitoyota
Sep 29, 2003 02:34 PM
