Shorter tires to change gear ratio...help
Old Dec 22, 2006 | 01:50 PM
Patrick Campbell's Avatar
great point on the 2WD for some reason I thought it was a 4x4. 3.90 sounds like the way to go.
oestreich84's Avatar
Why not try an edge ez, Van Aaken, something to give the truck a little more power? Could be just what the doctor ordered.
Old Dec 22, 2006 | 06:14 PM
Vagabond52's Avatar
Those 3.90 gears sound like the ideal combination that way I can keep the taller tires to get over the low spots easier, I like to spent a lot of time in the boondocks, although I'm limited by the two wheel drive.
Thanks again for the ideas
Ken
Old Dec 22, 2006 | 09:36 PM
Vagabond52's Avatar
Ken
I forgot the most important question, where is the best place to get a set of those 3.90 gears?
Old Dec 23, 2006 | 10:07 AM
bluebull's Avatar
click on link
www.jawsgear.com
www.accuautoparts.com
www.ring-pinion.com
Don't know about lowest prices or who's best but these should get yah started.
Old Dec 23, 2006 | 10:10 AM
bluebull's Avatar
After you get the ring and pinion installed the dealer can reprogram your trucks speedo through the data port under the dash.
Old Dec 23, 2006 | 10:12 AM
bluebull's Avatar
Forgot You can check here first to see if you like the new ratio. Just change tire and gear ratio's accordingly.
www.f-body.org/gears/
VikingDiesel
Apr 4, 2007 10:44 AM
sakisaki400
23
Dec 31, 2006 10:17 PM
streetsmoker
Sep 20, 2006 02:07 AM
unioncreek
Jun 23, 2005 09:19 AM
thumper 549
Oct 22, 2003 09:18 PM
