pulling
pulling
1999 24 valve, 150,000km, auto tran.. stock. No performance parts
I pull 24' Jyaco 5th wheel with double slide about 4 times a year.
tanks in camper are all empty on way their and way home..
Same terrain their and back
Bin noticing changes in pulling everytime I hook up. This past Friday I hooked up got on highway hit 4th gear, going a 100kmph and cruised for an hour without any loss of power...
Hooked up Monday got on highway hit 4th gear and had trouble staying at 100kmph. weather was raining on Monday and didn't seem like their was much wind. On Friday it was sunny and no wind...
Just wondering if any experienced this problem or is their something wrong with my truck
any ides
any ides
You might have picked up some crap fuel, check fuel filter, I tow a 36 ft 5th wheel, and even a little wind will change things, my truck likes cooler weather when towing, check air filter, let it breath, I clean air filter and change the fuel filter every oil change, a little over board I know, but cheap to do.
Drag (wind resistance) is dependent on air density, and speed. The speed value is a squared function in the calculation.
Heavy wet air as opposed to dry air will increase your drag. Without knowing the temp and atmospheric air pressure, it's impossible to calculate the precise amount, but it is significant. (likely in the 10% - 15% range)
At 100 kph, a 3 kph headwind will increase your drag by 7%.
Most of your power loss on the flat pulling a fiver is drag. I'm willing to bet your truck is running fine.
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
Extreme Diesel
16
Nov 29, 2002 06:14 AM
fahlguy
Nov 16, 2002 03:58 PM
PourinDiesel
Nov 10, 2002 07:20 PM
