propane or gas generator?
Old Dec 3, 2007 | 07:15 AM
rogerL1961's Avatar
does anyone have a propane generator? Do you like them?
Old Dec 3, 2007 | 09:24 AM
whitebuffalo's Avatar
we converted our little coleman generator to run on propane. we used a regulator off of a forklift. the main reason was b/c of the small fuel tank that came stock. now we can use a forklift cylinder and it'll run all night long. the way its hooked up, we can still run gasoline if need be, but i cant remember using it on gas since we converted it.
no comlaints other than the exhaust smells bad IMO
Old Dec 3, 2007 | 11:13 AM
PowerstrokeThis's Avatar
i would stick with running on gas because gas can be found more easily
Old Dec 3, 2007 | 05:08 PM
Pop-Pop's Avatar
Actually, propane is much easier to have on hand than gasoline is. Of course I'm assuming the generator is for home/emergency use if the power goes off. My electric-start Honda generator is tied into my 500 gallon propane tank that supplies the house. If the power goes off, these's no way I can get enough gasoline to operate the generator for a week or two because in my area, all the gasoline stations are out of service also. In addition, keeping a large supply of gasoline on hand, keeping it fresh and keeping it safe is a big challenge. If needed, I could run my generator for months with the propane I have on hand and I don't have to worry about keeping propane from getting stale.
Old Dec 3, 2007 | 05:18 PM
Scotty's Avatar
Top's Younger Twin
A propane generator and propane being added to the Cummins...a combo made in heaven.
Scotty
Old Dec 3, 2007 | 05:26 PM
P.J's Avatar
P.J
I don't have one, but for RV use I can see the advantage of LP over gasoline.
Gas is volatile and a pain to handle.
Propane is already in use in the RV (and detectors installed), easy to re-fill and store.
Propane will however net you less overall power on the same unit when compared to gas.
Old Dec 3, 2007 | 05:58 PM
slim51015's Avatar
Why not have both? http://www.propane-generators.com/
I converted my coleman over using a kit from them. The reason I converted is because I dont use the generator to often and the gas gets old. The propane I let it sit for 3-6 months, start it and runs great.
Old Dec 3, 2007 | 09:59 PM
stumpjumper's Avatar
we have the onan 3600kv propane and a small honda2000 gas for backup. love the onan nice and quiet and already having fuel on board is a plus. it does take up alot of room. if i was to do it again i would also consider teaming two honda 2000's together for when i go out in the dez. most rv campgrounds that i've been to have hookups. just my twocents. we do enjoy the onan and use it often........
Flatbed24v
Jul 31, 2009 10:57 AM
dssimecek
Sep 19, 2008 06:08 PM
PowerDually
Jun 12, 2005 10:51 AM
Soon2BDiesel
Apr 25, 2005 02:52 PM
chaikwa
Dec 5, 2004 09:33 PM
