Popup hitch Gooseneck adapter
Old Jul 31, 2005 | 02:21 PM
04.5HO600's Avatar
http://www.popuphitch.com/rv1.htm
anyone familar with this company and /or adapter???
seems easier than installing a regular fifth wheel hitch
just need the hide a ball for the camper then
thanks
Old Jul 31, 2005 | 04:21 PM
JAF's Avatar
JAF
My only concern is how close many fifth wheels run to the beds of our trucks. The farmer ball setup allows far more movement of the trailer so be really careful on off-camber ramps, uneven ground, etc. Other than that should be fine.
Old Jul 31, 2005 | 04:34 PM
bmoeller's Avatar
Gooseneck hitch.
Most people don't recommend using the adapters. It puts more stress on the pin box on the fifth wheel trailers. Can do lots of damage to the trailer if it isn't built heavy enough.
The goose does allow for more oscillation than a standard 5er hitch, but you can get tilting heads (side-to-side, in addition to the front-to-rear movement) on some of the 5er hitches.
Old Jul 31, 2005 | 05:43 PM
DanTana's Avatar
04.5HO600
04.5HO600
Check your PMs.
Old Aug 1, 2005 | 08:15 PM
RATTLINRAM's Avatar
Re: Popup hitch Gooseneck adapter
thanks
There are many opinions on these adapters and you really want to check with the manufacturer of the RV. Most do not suggest using them and will void their warranty.
You may want to take a look at this thread. CLICK HERE for one such example.
hudd1988
Dec 20, 2014 08:56 AM
440727
May 14, 2010 05:06 PM
kblranch
Nov 3, 2008 08:15 AM
natstayl
Sep 6, 2005 09:57 AM
jlasich
Mar 31, 2004 11:08 PM
