Please help guys?! Towing Speeds??
Old Mar 30, 2006 | 01:42 PM
HOHN's Avatar
It's the COMBINATION of 3.73s and 35" tires. It's not just one or the other.
As mentioned, your overall gearing is too tall for towing.
But you SHOULD be able to slide the shifter down and wind up the engine to keep some decent speed.....
Old Mar 30, 2006 | 01:53 PM
01350banshee's Avatar
Originally Posted by rickkari0304
Hello,
Well I'm the guy who had his truck at the dealer for 3 weeks with a dead ECM amd FCM. Probably unrelated to this gripe but here goes. I have a 24ft Keystone Sprinter TT maybe 8000 wet. My truck is auto, 35's with 3.73. I could not pull any of the grades/passes here in Washington State on I-90/H 26 over 50 mph. This is my first travel trailer towing. I have a 20ft boat that weighs around 3800 and pulled it numerous times with my 03 6-spd with 3.73's at 70 all day any pass or grade. Is this normal? Is it the 3.73's? Do all of you have a hard time towing TT/FW's? Thanks in advance. I was very upset I couldn't go the speed limit the whole way with my 48K truck.
I pulled the Grapevine (socal) North and South with my 11,000# 27ft toyhauler no problems with the stock tire setup. I got a kick out of seeing folks with their AC's off and windows rolled down crawling up the grade and here was little old me AC on, 55-60mph chugging along.
Old Mar 31, 2006 | 01:23 PM
Eskimo's Avatar
You 6 speed guys are funny. in 3rd or 4th in an auto on the road, the gearing is dang near the same as the 6-speed in 5th or 6th, and power loss? Once the TC is locked, there's not much...
Old Apr 1, 2006 | 12:58 AM
rickkari0304's Avatar
What RPM's are safe for the old Cummins?
Old Apr 1, 2006 | 05:03 AM
Any RPM you can attain with the accelerator pedal is safe. The engine has a governor. You could put a brick on the pedal and walk away, you will not hurt the engine.
Old Apr 1, 2006 | 04:17 PM
CoastalDav's Avatar
I found the tire/rear calculator in my backup files, Lucky. Can't post a link but if you want it, send me an e-mail CoastalDav@BellSouth.Net and I will send it to you. Its an excel spread sheet picked up over at TDR a couple years ago.
It's a good one. Has the dodge 6sp, 5sp and auto tranny ratios built in.
Here's a link to another good one. This one will tell you want rear ratio you have based on tire size, engine rpm, and mph.
http://www.csgnetwork.com/gearratcalc.html
Dave
digbog
14
Jun 4, 2013 09:42 PM
SuperiorRam
Mar 15, 2007 03:10 AM
bcb1962
Jun 24, 2003 10:16 PM
RLS
20
Feb 19, 2003 05:25 PM
RLS
24
Jan 9, 2003 12:23 PM
