owners of add on overdrives
anyone using aftermarket overdrives. i need some real road use comments. let me know the brand, any pro or cons of the unit. or any special things i should know before buying a unit.
it will be going into a truck towing 10k with a 727 auto. i'm able to tow ok, but i'm spinning the engine over 3k on the hiway empty.
when towing i drive slower so it's not an issue then.
thanks
thanks
Guess the lack of responses is an answer in itself.
I had looked into those when I had the old Ford dooley and talked to the service manager of the biggest tranny shop in the Baltimore area, and he said that they loved those things - removing them from trucks of unhappy owners and restoring the truck to their original configuration.
I know there are lots of "good" reasons to put them on; but he talked me out of one. Not sure if it'd pay for itself, even if you have $2K to burn.
My sons truck has the Gearvendor over / under drive on it and it is schweeet. We pulled my truck on my 30 foot gooseneck from Virginia out the Indiana and it was a real life saver on the mountains. It kinda splits the gears and helps a lot especially since his truck has the 410 rear. Drops the engine speed around 400 rpm's when you go into the high side of 5th.
Someday I will have a US Gear OD. I have heard that it is not as well suited to an auto as the gear vendors, but it will handle 2000 lbs of torque.
The GV is all hydraulic, I think, so it is alot better suited to the auto tranny.
Chris
Chris
tool
Mar 12, 2008 09:46 AM
dodgemaniac
Jun 12, 2007 08:21 AM
johnr9q
May 17, 2006 12:13 PM
gsbrockman
Mar 3, 2006 07:59 PM
