Nylon Lube Plate
Old Jun 10, 2008 | 11:29 AM
01RAMer's Avatar
Nylon Lube Plate
I have always used that Nylon Lube Plate and love it, but now I have a question. How often should I change it, or , when should I change it? I look at it and it looks fine, but is there something I should see that tells me it's time to change it?
Old Jun 10, 2008 | 01:05 PM
stumpjumper's Avatar
i only change it when it breaks. but you should always keep a spare for when this happens. it usually happens to me when i try to back underneath it with the pin a little too low.
Old Jun 10, 2008 | 02:00 PM
shorthair's Avatar
If you never lift your trailer when you back into it the "slick disk" will last over 1/2 million miles easy.
Old Jun 10, 2008 | 03:26 PM
tankeryanker's Avatar
Yep I only change mine when I break it. Going on 4 yrs on this one. I grease the jaws & swival from time to time. I use slider grease in a spray can. It's for the track & gears on the slides but keeps the hitch operating properly & that grease dosen't collect dirt.
Old Jun 13, 2008 | 07:31 PM
HiJenks's Avatar
TankerYanker
Where do you get this "slider grease" and what's the "real name" for it.
I have pads on both my trailers and like most of you change it when it breaks.
I wouldn't haul without it.
Old Jun 13, 2008 | 09:30 PM
PChouinard's Avatar
And I'll sell you the only bridge that leads to a tropical island where pigs fly.
The plates are the only way to go for the tongue weight of travel trailers..
mknittle
Mar 11, 2015 10:47 AM
dssimecek
Mar 10, 2008 04:58 PM
MrSlug
Jan 7, 2007 03:47 PM
JD farmboy
Oct 17, 2006 11:57 PM
BigWaylon
Apr 24, 2006 10:40 PM
