Trailer lock
Trailer lock
I have an 18' car hauler with a hammer blow-bulldog hitch. I have a lock for it for when it is sitting in storage. What I'm looking for is a lock for when it is hooked to my truck. I have tried the long skinny locks that come in the set to lock the receiver. But it is too short. I need a lock that would replace the pin behind the slide.
This is what I have.
I have never seen a lock pin that long. I'm thinking you'd have to either change the hitch to a different type, probably desirable, or see if you can drill a hole at the bottom of the hick sheet metal, just behind the collar, in locked position, that you could put a lock into. I can't tell from the picture of the metal wraps all the way around the bottom , juts behind the collar, so I'm not sure if that would work. Another custom possibility, would be to drill right beside the release lever, or even through it and the hitch sheet metal, so you could use the small receiver pin there. It sure looks like it opens up there, and would be readily accessible from the bottom to put the pin through at the release lever.
Chris
Chris
I have the same type of hitch on my stock trailer and am also interested in finding a lock.
I thought about paddle locking the breakaway chains to the truck, but a simple bolt cutter would defeat that.
Any other ideas?
Any other ideas?
Found some.
http://www.etrailer.com/c-cl.htm
This one in particular:
http://www.etrailer.com/pc-CL~2847DAT.htm
Chris
Chris
Found some.
Chris
Chris
xp8103
06-02-2006 07:00 AM
mr T
21
06-01-2005 08:48 AM
damon_achey
06-07-2004 03:33 PM
