Mirrors
Re:Mirrors
[quote author=Shovelhead link=board=11;threadid=8083;start=15#80320 date=1039897085]<br>Luke S.<br>What are the chances the Dodge would build/market as a package the newer powered/heated towing mirror heads with the 2nd Gen. bases? ???<br>I know I'd go for a set.
<br>[/quote]<br><br>Shovelhead, I'm doing the mirror swap on my 99 and it's not an easy task. :
I had a buddy give me a set of the factory towing mirrors of an 01, which are the flip-out mirrors with no power and no heat. You have to take those mirrors and remove the mounting bases from mirrors. I have ordered a set of 03 power/heated towing mirrors for an 03 as well. (the one's Luke has for $345, those are just for 03's and up) You have to take those mirrors and remove the mounting bases as well. Once you have the mirrors taken apart you must put the power/heated 03 head units on the older bases. Then you can mount them to your truck and splice in the correct wires to power them. I will see if I can find the post on the TDR with the directions and post a link.
It's alot of trouble for a set of towing mirrors but I believe once I'm done it will be well worth it. 8)<br><br>DB
Re:Mirrors
Here's the link to the directions for the hybrid 02/03 towing Mirrors.
Directions
Be very careful when removing the locking ring that hold the spring in.
When that puppy comes out it's moving fast.
Here is a link to a post I made lst week about the dissasembley of the mirrors.
Look Out
DB
Directions
Look Out
DB
Re:Mirrors
I just ordered the 03 mirrors to complete the electric conversion and only paid $315.00 + shipping.Also got a great deal on the 2000 stock switch. It's from the same people that are selling the non-electric on E-bay.I tried to buy from my local ******* and was told they are on national back order.These guys said they would ship today. I only have a phone #(800)559-6698.Thanks for the advise about the spring clip on base.
Re:Mirrors
Guys, i have a 96 2500 and i need to look into these mirrors as i cant see around my 28 foot enclosed race trailer. What will i need to purchase from dodge and is there any hidden tricks to the swap.
Re:Mirrors
If you are just wanting the non powered units it's a simple 20 minute install.
Just call you local dealer and tell them you want a set of the flipout towing mirrors for your year of truck. The kit goes from anywhere from $200 up to $300 just depending on the dealer.<br><br>To get the power and heat it's a little more involved, just click on the link above to find out.
<br><br>Good Luck.<br><br>DB
Re:Mirrors
I'm VERY interested in this, so today I went and looked at an '03 with the swing-out power/heated mirrors. I can see the need to change the bases - they're part of the front corner of the window, and the '03 slopes back sharper. The '03 base & arm is also a lot larger than my '02 power/heated mirrors, and before I spend 350 bucks, I'd like to be sure we're talking about the same thing. Here's a pic of one of my mirrors. The '03 swing-out arm WILL fit my '02 base, right ??.......even tho' it comes off a larger base ?? Since my '02 already has the mirrors installed, is it practical to dis-assemble them on the door ?? After reading what you said about the spring, I think I'll tape heavy cardboard over the paint below the mirror and wear safety glasses. I have the **** slip-ons now, and the '03 swing-outs will gain me about 2", as well as much bigger mirrors. Both are very definite pluses. Thanks a lot for your help.........and patience. Lar.<br><br>[quote author=DarrellB link=board=11;threadid=8083;start=30#118284 date=1048135859]<br>Here's the link to the directions for the hybrid 02/03 towing Mirrors.
<br><br>Directions<br><br>Be very careful when removing the locking ring that hold the spring in.
<br><br>Here is a link to a post I made lst week about the dissasembley of the mirrors.<br><br>Look Out<br><br>DB<br>[/quote]
Re:Mirrors
biglar,<br><br>You have the small power/heated mirrors, you need the factory flip-up tow mirrors, AND the '03 factory power/heated flip-up tow mirrors, for this swap. If/when you do get both sets of mirrors, you'll want to take them apart on a bench or the like, all the work hunched over will make your chiropractor even more wealthy.<br><br>Good luck, Rob
Re:Mirrors
Time to crawl the wrecking yards, I guess. What years did they have those flip up mirrors ?? They were the non-power, non-heated ones, right ?? Anyone interested in buying my old ones ?? Lar.<br><br>[quote author=Rob Thomas link=board=11;threadid=8083;start=30#121754 date=1048915360]<br>biglar,<br><br>You have the small power/heated mirrors, you need the factory flip-up tow mirrors, AND the '03 factory power/heated flip-up tow mirrors, for this swap. If/when you do get both sets of mirrors, you'll want to take them apart on a bench or the like, all the work hunched over will make your chiropractor even more wealthy.<br><br>Good luck, Rob<br>[/quote]
Re:Mirrors
Yes, you need the non power flip up bases, but good luck just finding those without the rest of the mirror. The non power flip up mirriors were only offered in '01 and '02, maybe a few late '00's had them as well.
Later, Rob
BTW, I call them, "bases" technically they are named "sails", FWIW.
Later, Rob
Re:Mirrors
Good Luck finding a set of the 03 powered/heated units a well.
It seems Dodge has them on National Backorder. :'(<br><br>I was told that they "might" :
be in by middle of April. >
<br><br>On day I will have Power/heated folding mirrors.
<br><br>Oh yea, you can forget the junk yards, everyone I went to around here that even had a wrecked Dodge was a waiste of time. The things are so stripped by the time you get to them there isn't much left.
<br><br>Good Luck<br><br>DB
Re:Mirrors
ok gang. went to Sternbergs today and bought the mirrors from them for 245. and did the install. really easy and the looks are there.<br>Shame they didnt include more trim clips as i used the old southern indiana panel removal tool( pocket knife) and proceded to destroy most of them.<br><br>TW----so much for the touchless carwash >
Jblak87
Mar 26, 2012 05:30 AM
RuralCruiser007
Jun 13, 2010 09:42 PM
ChicagoSnow
56
Jan 26, 2008 12:09 AM
B.A.Ram
Jan 12, 2006 07:29 PM
1320
Apr 30, 2004 09:13 AM
