Mag-hytech
Old Feb 16, 2007 | 07:59 PM
albrightfour's Avatar
Mag-hytech
Is mag-hytec DD a good addition to my tranny for towing?
Thanks,
John
Old Feb 17, 2007 | 01:42 AM
TexasCTD's Avatar
Yes. It provides 4 quarts over stock for extra capacity and cooling. Most tranny builders recommend them....or a similar product.
Old Feb 17, 2007 | 04:21 PM
3500lly's Avatar
Yes, it is definately worth it, will help you run cooler
Old Feb 18, 2007 | 09:01 PM
jiMMyCTD's Avatar
HIJACK!!!
should help your auto definatly.
what about the rear end cover. Im trying to convince myself to get the cover for my 99 since its up for lube service. I pretty much only use the truck to tow with.. nothing special just 6-7k almost everyweekend in the summer through the sierras in the heat etc...... worth 240$ im leaning towards YES!
jiMMy
Old Feb 18, 2007 | 09:28 PM
kawiram's Avatar
Looking through the Geno's catalog the Double Deep, gets you 4 quarts for $270, the deep gets you nothing on 98 and up for $225, and the PML gets you 2 quarts on for 98-06 for $189. Only the PML does not include a pretapped fitting for temp sensor, only a flat area to put one.
Old Feb 19, 2007 | 01:17 AM
TexasCTD's Avatar
jiMMy
I don't think the MH differential cover is really that necessary. I have one and I like it. Glad I got it. But it is more for a the coolness factor than anything. I see alot of high horsepower trucks and heavy haulers that pull without them with no problems.
I am debating about putting one on the front diff.....but I would probably go with PML because MH has some rubbing issues on the front that they haven't (to my knowledge) corrected.
Old Feb 19, 2007 | 07:52 AM
Hvytrkmech's Avatar
I have the double deep on my trans and the rear diff cover. The trans pan not only holds more fluid but als hold the trans rigid so when you are towing it does not flex thus prolonging tran component life.
The rear diff cover does lower the rear axle temp because of the increased fluid capacity but it is really nice for changing out your fliud, just pull the plug and let it drain.
This is my third truck running Mag-Hytec trans and diff covers, and as long as I tow I will have them on whatever truck I may own.
Old Feb 19, 2007 | 06:24 PM
GAmes's Avatar
I say yes. I credit it (and Royal Purple 85-140) with over 493k miles of failure free towing, and I do tow heavy at times. Be advised it increases the capacity to 7 qts.
Dan Marino
14
Dec 21, 2007 07:01 PM
dodgezilla04
Jun 7, 2007 03:43 PM
1stTimeAround
Sep 7, 2006 07:51 AM
jiMMyCTD
May 19, 2004 03:13 PM
6cylinders
Dec 4, 2003 11:02 AM
