Loaded Toy Hauler
Old Mar 7, 2008 | 04:16 PM
CODODGE2500MAN's Avatar
Loaded Toy Hauler
Let's see the pics of the loaded up toys....specifically the interior photos!!!!!
Thanks
P.S. I've looked at all of the photos in both truck and trailer rigs, but I am trying to see if anyone has fit a jeep in the back of a toyhauler. Jeeps in the gallery!
Old Mar 7, 2008 | 05:23 PM
doznfire's Avatar
I have seen a jeep put in a trailer like mine but I wouldn't do it. Most toyhaulers out there aren't built heavy duty enough for that. What brand of trailer are you looking at?
Old Mar 7, 2008 | 09:22 PM
Jeff in TD's Avatar
I just went to an RV show and was checking out the Inferno series by K-Z.
Super-loaded.
In the garage I noticed a beer tap and collapsable bar stools. In the living area there is a staircase up to the loft bed above the divider wall. On the garage side is the access door to the keg-o-rator (sp?) that is tucked under the stairs...
Anyway, those buggers are very nicely equipped. I don't recall if the carrying capacity of the garage section is adequate for a jeep, though...
Old Mar 7, 2008 | 10:06 PM
bkrukow's Avatar
Heres mine loaded with a 700 Sportsman, 800 Outlander,660 Grizly and 700 Raptor. No Jeeps but its loaded toy hauler. Hard to say what it all weighed but just the machines where a little over 2500#. Then we had all kinds of other gear strapped to them and piled in around them so I would say its safe to say theres 3500# + in there.
Old Mar 8, 2008 | 09:02 AM
2003Ram's Avatar
Many toyhaulers could handle the weight over the axles, but the ramp door is a different story. Check that capacity too.
Old Mar 10, 2008 | 11:58 AM
Thanks~
The particular jeep is actually just over 3500 lbs. (see sig) I'm mostly worried about the height, especially with the toy haulers that have a queen bed in the back.
The jeep itself is only about 12 feet long, so length isn't such an issue.
How tall is your entrence when the bed is up? or if you don't have a bed?
Thanks!
Old Mar 10, 2008 | 08:58 PM
bkrukow's Avatar
I am not sure what the height is with the bed up. Its high enough I can walk under it with lots of clearence and Ime 6'2". I would guess its around 6'6"-7'.
Old Mar 11, 2008 | 12:21 AM
JuzPlaneKrazy's Avatar
Old Mar 11, 2008 | 03:14 AM
ChrisM55's Avatar
OHHH, I miss my RC planes, I mean missles
Man I destroyed alot of Balsa wood
Chris
Old Mar 11, 2008 | 11:26 AM
bentwings's Avatar
We are getting ready. 118" B-25 nearing completion, 96" P-51 ready to fly, pregnent with Corsair and Black Widow.
Old Mar 13, 2008 | 07:12 PM
cruiserdar's Avatar
Here are some good posts I found in search
https://www.dieseltruckresource.com/...archid=2155748
I have some info on building my toyhauler for a jeep on my webpage..
http://www.freewebs.com/cruiserdar/index.htm
Old Mar 25, 2008 | 01:44 PM
91rangerturbo's Avatar
That's pretty wild.^
Old Mar 25, 2008 | 04:24 PM
Rocky's Avatar
Track Day
Track Day at VIR
Old Mar 25, 2008 | 06:10 PM
C Minus's Avatar
This weekend Portland International Raceway.
Shake and Bake!
Old Mar 26, 2008 | 08:28 AM
Bonshawman's Avatar
FYI: on my 44' hauler (18' garage plus RV quarters), the rear door is 95" wide, and 77" tall, with 73" of interior height (it also an inclined floor just inside the door which makes for more aft height). My WWII Ford GPW (Jeep) goes in fine as does any normal height car. Don't know if the newer/shorter toy haulers can really accommodate a Jeep, and if even flattening the tires would work, if your length/width are OK. Soft tops w/drop W/S work, but of course the roll-bar is the problem on most later Jeeps.
