Help Wiring Trailer
Old Jul 6, 2007 | 12:35 AM
EverydayDiesel's Avatar
Help Wiring Trailer
I bought a 4 way flat from uhaul yesterday and the first one was bad. The left and right flashed when making a left turn. I took it back and got a new one. This one is not doing that but I did have a question about the wiring.
http://store.uhaul.com/product_detail.aspx?id=120
The brake input (from the brake light) has 12V going into the box (tested with a meter). The output of the harness (that connects to the trailer) has 1.8 coming out of both the left and the right sides. I highly doubt thats enough voltage to run the brake lights ... am I wrong? Im assuming that there is suppose to be 12v coming out of there.
Is this another bad box? (Just for the record..I did install alarms and such for 3 years so im good with wires and such)
Thanks for the help!
Old Jul 6, 2007 | 10:08 AM
GAmes's Avatar
Are you using this adapter on your Dodge? If so, you don't have separate turn and brake lights so it won't work. You just need a seven to four pin adapter.
Old Jul 6, 2007 | 10:52 AM
whoever had this truck before me hacked up the wires so I had to hard wire it in. It wound up being another bad box from uhaul. Later on a guy that knew what he was doing sold me a kit that just plugs right into the factory brake light housing and everything worked great.
Micaiahfied
Nov 8, 2006 10:35 PM
Evildiesel
Jul 2, 2006 06:39 PM
Big Joe
Aug 19, 2005 10:27 PM
Nevada
Aug 3, 2004 05:48 AM
dsljunkie
May 11, 2004 10:54 PM
