Help with trailer wiring.
Old Aug 18, 2005 | 02:23 PM
Big Joe's Avatar
Hey guys, I was wondering, I am fabbing a customized car/toy hauler, I was wondering how I needed to set up the turn, and stop lights.
Do I need a separate light for my turn lights, or does dodge separate it at the plug so you dont have to run a separate turn light.
Also, I would love it if someone could tell me, and or send me a wiring diagram of the 7 pin connector for the trailer plug, thanks Joe.
Old Aug 18, 2005 | 02:44 PM
rock's Avatar
It takes 4 wires. left turn/brake, right turn/brake, ground, running lights. Turn and brake light are same wire. Maybe someone else has the 7 pin breakout, I don't.
Old Aug 18, 2005 | 02:52 PM
rock's Avatar
Try here
http://www.iboats.com/sites/trailerb...ages/tg403.pdf
Old Aug 19, 2005 | 02:47 PM
TonyB's Avatar
Don't forget to add the electric brakes....I wouldn't want to try to stop that much weight without them!
Tony
Old Aug 19, 2005 | 04:18 PM
natstayl's Avatar
As already said, brown wire is the side markers and running lights, yellow is left turn and left brake lite, green is right turn and right brake lite. Now if it was me (and it was two months ago) I would add backup lites. The backup lite feed is the center pin of the truck's RV connector and I would use purple wire to the back of the trailer. And if you're gonna have a break-away switch to engage the electric brakes should it separate from the hitch, run a red 12+ wire to the break-away gel cell battery to keep it charged.
Nat
One more thing, the electric brake lead at the RV connector doesn't work until you hook up a brake controller to the connector under the dash. You should have seen the short controller pigtail inside your glove box or armrest.
Old Aug 19, 2005 | 10:27 PM
dodgezilla04's Avatar
look at the cover for your trailer wiring on the back bumper of your truck. it give the pin locations and their use.
Lomarker
Nov 22, 2006 08:18 PM
Micaiahfied
Nov 8, 2006 10:35 PM
Evildiesel
Jul 2, 2006 06:39 PM
Nevada
Aug 3, 2004 05:48 AM
dsljunkie
May 11, 2004 10:54 PM
