Hellwig and a 5" exhaust
Got my Hellwig last week and tried to install it this weekend. It simply will not fit with my 5" exhaust. Anyone have similar issues? Am I just an idiot?
You are not an idiot. It is tight install even with certain aftermarket 4" tails. I have MBRP 4" duals with the Hellwig rear sway bar and it is tight. I have no problem envisioning 5" being too big to fit...without modifying the tail pipe, anyway.
Ok, thanks. I was looking at it and was thinking the stock exhaust must be tight because I'm only 1/2" bigger and there was just no way it was going to fit with my 5". I may have to find someone who can bend 5" and start fabricating something for a tail pipe that will work.
I have a 5" Flo-Pro with the Helwig. It's tight to the point of hitting when I bottom out the suspension, but it just dented what it need to, & it's all good now.It may have more to do with the placement of the pipe where it goes over the axle. Some will work better than others.
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Agades
Feb 8, 2007 05:22 PM
BEHRMAN
May 4, 2004 12:09 PM
