Gotta see this !Tire reseat field repair
Old Apr 19, 2009 | 08:46 PM
Swarthy Dago's Avatar
ck this out. cool trick if you're stuck somewhere. sorry didn't work, gotta figure out how to add the video.
Old Apr 19, 2009 | 09:37 PM
Checkmate's Avatar
starting fluid ???
Old Apr 19, 2009 | 11:12 PM
johnh's Avatar
propane????????????????????????
Old Apr 19, 2009 | 11:52 PM
biododge1's Avatar
I'll take a shot-hose plumbed to a spark plug hole, crank engine, instant compressor
Old Apr 20, 2009 | 03:27 AM
Travis_'s Avatar
WD-40 and a lighter? I saw that on a discovery show awhile back. They had these beefed up Toyota Land Cruisers running huge flotation tires in the arctic. One lost its bead and that is what they used to get it to seat.
http://arctictrucks.com/
Old Apr 20, 2009 | 06:34 AM
Checkmate's Avatar
Too bad the new wd-40 won't work. It's not nearly as flammable as it used to be.
Starting fluid, then trickle it out the side and throw a match at it.
Old Apr 20, 2009 | 09:09 AM
duner's Avatar
a few drops of gasoline works too.
Old Apr 20, 2009 | 11:09 AM
cincydiesel's Avatar
I've done it many times to the tractors and quads
Old Apr 20, 2009 | 12:55 PM
Darryl&Rita's Avatar
Bettin' on Ether, a.k.a. Starting fluid. Lift off the ground with a jack, spray inside tire, pull can back, add spark. Do it lots on 16.5" wheels on the old Ford.
Old Apr 21, 2009 | 02:58 PM
Fueling around's Avatar
That's how the local tire shops get the large tubeless flotation tires to seat the bead. The biggest tires take 3 small cans of ether.
I don't know if the new WD-40 works either. The old formula made great starting fluid. Only needed to carry 1 brand on the service truck.
Old Apr 21, 2009 | 03:52 PM
oldmikegraham's Avatar
That is the way we did it on deployment in the Seabees. We called it fireballing. Used starting fluid or brake cleaner out of aerosol cans.
Kind of funny that in the name of safety we were told not to do it anymore, at the same time we were still airing up split rim semi tires without a cage though!
Old Apr 21, 2009 | 06:58 PM
does anyone have that video ? i thought that was pretty cool emergency repair. i saw it on bloodydecks, but i can't figure out how to post it up here. yea the guy just sprayed wd40 into the tire, lit it and bam the tire was seated and partially filled. starter fluid could inflate it up good i'd wager.
Old Apr 21, 2009 | 10:20 PM
johnh's Avatar
just copy and paste
Old Apr 22, 2009 | 06:34 PM
cLAYH's Avatar
Tons of these on Utube
http://www.youtube.com/watch?v=vLtBojvDEyc
Search "tire inflate fire"
Old Apr 22, 2009 | 08:07 PM
CODODGE2500MAN's Avatar
I've gotta say that's pretty cool....
Wont be my primary way of doing it, but a nice "get you out of trouble" idea. For now, I'll hope the beadlocks stop this from being a necessary skill.....
Thanks!
