Fifth wheel hitches?
Old Jan 8, 2005 | 12:07 PM
hippie's Avatar
300# is a lot of extra weight, I would have to get rid of a couple of my toys if my hitch was that heavy...
Old Jan 11, 2005 | 03:27 PM
supr's Avatar
My vote is also Pullrite, for the reasons already mentioned. Further, there is a Goose-neck alternative, if needed. Perhaps the best part is the HD rails that attach directly to the CTD frame, which I think are pre-drilled(Don't know that for sure).
You pay more for the Pull-rite, but you will enjoy whenever you hook up. You will not wear it out.
Old Jan 12, 2005 | 07:22 PM
ed cloud's Avatar
B&W Turnover ball
OK guys I have had a Turn over Ball with the Companion Hitch on my 04 Dully for about a year and love it Im pulling a 2004 Teton weight of 16200 dry weight I have had no problems I like this one because it is so easy to remove and you have the whole bed empty. The head pivots from side-to-side (a full 7 degrees) to help prevent binding, as well as from back-to-front. A single hydraulic shock absorber helps to stabilize the side-to-side motion. The shock also holds the head level for easier hook-up. Vibration-dampening polyurethane bushings act as the base for the front-to-back pivot of the unique saddle assembly of the coupler.
http://www.turnoverball.com/
__________________________________________________ _________________________
2004 Ram 3500 SLT Laramie, 4x2 Quad Cab, Auto-Tran. 4 Speed, Fog Lts., Trailer Tow Grp., Fold Flat, Tow Mirrors, B&W Turn Over Ball / With Companion RV Hitch, 3 Step Nerf Bars, Extang Full Tilt Tonneu Cover, Husky Mud Flap’s. 60 Gall. Aux. Tank W/ Elec. Switch And Gauge inside.
Old Jan 13, 2005 | 10:23 AM
Mtman6698's Avatar
Love my Pullrite. Never had a problem with it. Take out 4 pins and it leaves me with a flat bed. I did have to help someone the other day with a Reese. The only way it would open up was to use a crowbar on the jaws. Not sure what the problem was; couldn't get the handle to move. They said this was not the first time. They are going to take it to a shop that handles Reese and see what they
say.
Wayne H.
Old Jan 15, 2005 | 10:57 AM
BoomR's Avatar
I have a Reese 16k dual pivot slider which has worked flawless for me the last 3 years. I pull a 29 foot fifth wheel trailer. Before purchasing mine, I did a fair bit of research before deciding on the Reese. The double jaw locking mechanism has worked like a charm.
As per one of the posts earlier, the rail system is not interchangeable between brands.
The Reese that I have is easy to remove, just pull 4 pins and lift out. The rails remain in the bed however I have installed a thick 1" rubber mat, which I cut to sit between rails and on each side and this evens out the bed nicely.
If you have not purchased a hitch yet, I would say you can't go wrong with a Reese. If you choose another brand, it means drilling more holes in your bed and possibly the frame too if things don't line up.
Cheers.
Old Jan 23, 2005 | 06:11 PM
procrastinator's Avatar
Does anyone mind telling me what the rough price for the turn over ball 5th wheel hitch is?
James
Old Jan 23, 2005 | 06:20 PM
FiverBob's Avatar
Hidden Hitch makes a very good 18K unit at quite a bit less money than the Reese and it looks and works like Reese. Some say they are owned by Reese. This will hitch to your Reese setup - - in fact mine is a Reese mounting brackets and rails.
Old Jan 23, 2005 | 11:14 PM
Jeff in TD's Avatar
procrastinator,
Roughly $325 for the goose setup, plus about $650 for the 5th wheel...
I think I gave around $1100 for the hitch, an electronic controller, and a brake cable extension...
Old Jan 24, 2005 | 12:54 AM
Duelin's Avatar
http://www.renegademanufacturing.com/
Take a look at this unit. Dave Smith Dodge in Kellog Idaho sells them, or I suppose they can be ordered direct. I have the hitch and the 5 th wheel adaptor and am quite pleased with the quality of constrction , and as a ex welding inspector I am quite picky. It was easy to install --after getting over the shock of cutting a hole in the new bed !!!
Old Jan 24, 2005 | 08:58 AM
Jeff in TD thanks for the info.
Procrastinator
misterKTM
Feb 11, 2015 01:21 PM
tonycamacho
Apr 25, 2009 10:44 AM
FAY
Oct 27, 2006 09:05 PM
Burpl
Jun 23, 2004 07:19 AM
ronster
Nov 19, 2002 08:22 PM
