Exhaust Brakes ? are they all operated by vacuum ?
Another happy PacBrake PRXB owner here. I don't think it was mentioned in the above posts so I'll try to add some info. I installed my EB myself and is definetly a DIY project. On my 05 the brains of the operation comes straight from the Cummins ECM. The ECM is already programmed for exhaust brake operation and controls the signal to turn the air compressor (or solenoid depending on how you have it set up) on. The air compressor then extends the air cylinder which engages the butterfly valve. So, in a way, the PacBrake is electrically controlled and goes on and off seamlessly just the way Cummins engineered it too.
Here's kind of a random question... Could you tap into the air tank and use that to provide air for something like an air horn? I guess it'd have to be at 120 PSI, which I'm not sure if it is or not.
[QUOTE=P.J;1300972]NO.
From what I read, the vacuum operated pump is VERY expensive to replace, not to mention it is constantly running as the motor runs.
QUOTE]
the only time my vacum pump starts is when the jake closes and the conv locks
QUOTE]
Actually Chris, the pump runs all the time as it is spun by the serpentine belt. The ECM opens the solenoid and allows vacuum to be applied to the actuator on the brake after it locks the converter but the pump is spinning when your truck is running.
Brian
Brian
Something like $730.00 to replace?
I believe thats what other posters have said about buying it at the Dodge's retail price, and I also remember posts about buying it from Cummins (or another source) for less than 200 bucks. I have the documentation with both Dodge and Cummins part numbers but I won't worry about it til if and when the vacuum pump actually packs it in.
Pacbrake is the way to go!!
bnold, I think I can live with two seconds. I see PacBrake has an accessory part to get it to come on immediately when your foot is off the go pedal. Then they have another accessory part, a clutch switch to disengage while shifting. Sounds like those two items are just too much wiring though.
The two seconds I can live with I think. When I was driving OTR for my paycheck, you didn't have to wait at all for the engine brake to cut in, but I'm sure I could adapt.
I choose to run a air actuated vs. vacuum for a couple reasons. 1.It is a backup braking system, on vacuum actuated models if the vacuum pump fails the truck has no service brakes or exhaust brake. This way I have both. 2. I wanted onboard air anyways, I have a 100% duty cycle viair compressor plumbed into a 5 gal air tank that is dried and then goes to my ebrake or an air outlet attached to my grill guard.
Mule Skinner
May 29, 2007 12:13 PM
pluguglyinhere
Jan 1, 2007 12:25 AM
Uncle B
Dec 10, 2006 10:55 PM
w4xtc
Feb 22, 2004 08:42 AM
