Dumping Black Water
Old Jul 28, 2008 | 04:39 PM
  #31
Colo_River_Ram's Avatar
With age comes the cage
I read on another thread where one guy would put a bucket full of ice cubes down the porto and cruise around for a while to get things broke loose..Prior to the flush.
Old Jul 28, 2008 | 04:49 PM
  #32
5Oclock's Avatar
My Raptor has a compartment on the side for the sewer hose. It is big enough for a 10' & 25' hose along with all the fittings. I just rinse real good and store it.
And then of course, wash my hands.
Old Jul 28, 2008 | 05:19 PM
  #33
P.J's Avatar
P.J
This is a common method for helping out with false sensor readings too.
You guys may also want to search something called the "geo" method. It is a cheaper alternative to conventional tank treatment chemicals. Worked well for me.
Old Jul 28, 2008 | 09:04 PM
  #34
Utundra's Avatar
Off subject, but how many of you guys use disposable latex gloves when draining the tanks?
My wife found a case of 10 boxes lying on the side of the road. Each box contains 100 Nitrile gloves. 1000 total gloves. Box in the camper, box in the garage, box under the sink, a box each for a few close friends. That was last winter and I still have 4 unopened boxes sitting in the basement.
They are great for handling the stinky slinky, oil changes, mixing herbacides, etc.
Old Jul 28, 2008 | 09:59 PM
  #35
Spooler's Avatar
Originally Posted by Roperteacher
LOLOL SInce I rodeo, we wait until we are on a desolate stretch of road and well " Let her rip".. LOLOL No hose needed
You give a whole new meaning to the world Road Grimm......yack!!!!!
Old Jul 29, 2008 | 09:16 AM
  #36
cincydiesel's Avatar
Originally Posted by irocpractice
(2)I have a small spray bottle and mix up a fresh solution of bleach/water prior to servicing the system.When complete,I spray the hose,connections,what ever has been touched.
Great idea with the bleach bottle. I'll have to try that
Old Jul 29, 2008 | 10:50 AM
  #37
Busboy's Avatar
Big jet aircraft that use vacuum toilets have sensors that will shut off the vacuum blowers when the tank gets full. Well the sensors get covered in crap and none of the toilets work. A trick is to raid the galley and get all the left over ice cubes and dump them down the toilet furthest away from the waste holding tank. You have to trick the computer to get the blower into working but the ice cubes come down that pipe pretty fast (they don't call them 500 MPH $hit suckers for nothing) and enter the tank knocking off the crud on the sensors. Using ice cubes works in this method but I can't see it working if they just sit in the tank and get bounced around a little.
Old Jul 29, 2008 | 11:00 AM
  #38
supr's Avatar
I have read that the ics cubes do help the sensors. I think having 2-5 gallons and fresh water(after dumping the tank), with chenical(Thetford or whatever) works exteremly well keeping the tank clean. The main thing is never let your black tank run dry, ever.
Old Jul 29, 2008 | 11:58 PM
  #39
You need to drive our roads...it will be more than just a little bouncing around
Old Jul 30, 2008 | 11:43 AM
  #40
2003Ram's Avatar
Camping world sells a PVC pipe for sewer hose storage. It comes with brackets for mounting. I put mine above the drain pipe on my toy hauler.
Old Jul 30, 2008 | 12:07 PM
  #41
Busboy's Avatar
Roads? You have roads? All we have up here is wagon tracks
Old Aug 1, 2008 | 05:41 AM
  #42
AlCorr's Avatar
My 5er came from the factory with a black tank flush. It's the best way to keep the tank clean also keeps the sensor's in the tank clean, no false readings as P.J. said.
Old Aug 1, 2008 | 05:59 AM
  #43
AlCorr's Avatar
After dumping my tanks, maybe every 3rd. or 4th. time, I always add about 10 gallons of water with 2 cups Calgon water softener powder and a 1/4 cup dawn dishwashing soap. We then drive home and to the next campground letting the concoction slosh around in the tanks. You won't believe how dirty the water is that comes out. Once at the next campground we rinse and drain tanks and the water comes out perfectly clear.
So far this method has worked well for us.
Old Aug 1, 2008 | 09:30 AM
  #44
staarma's Avatar
I have heard of the water softener trick before. I'll have to try that before winter storage this year. How much dish soap do you use so it doesn't foam too bad?
Old Aug 1, 2008 | 09:45 AM
  #45
Fueling around's Avatar
I use automatic dish wash soap for these projects. It is low suds plus has grit to knock the scum loose. cup per 8 gallons
