Dump trailer switch
Old May 6, 2011 | 12:32 AM
Actiontaken's Avatar
Dump trailer switch
I am wanting to install a rocker switch in the cab to run my dump trailer.
Anyone done this?
I am having trouble finding the right switch, Trailer is power up and power down non reversing motor (two selinoids, one up one down)
4 wires to the handheld switch which I have tried to duplicate in the cab but to no avail.
Old May 6, 2011 | 12:46 AM
just need a switch to run the motor in the trailer.
Old May 6, 2011 | 12:57 AM
Colo_River_Ram's Avatar
With age comes the cage
Does the hand held have any indicator lights in it? If so..
one wire is 12v
one to up relay
one to down relay
one to ground
Go the the mfr website and look for an owners / wiring manual
Old May 6, 2011 | 01:23 AM
Switch
Thanks,
I have talked to manufacturer of the motor but did not askfor schematic
Of the switch, I will try that in the morning.
I have determined that the switch needs to close circuits from power
To solenoid and ground for each direction, at least that is what I think the original switchdoes.
Old May 6, 2011 | 08:14 AM
Jaxom's Avatar
Perhaps a switch from a winch mfg'r??? HD relay to power in and power out.
Warn makes a wired remote with a rocker switch. You could also get the wireless kind if it makes it easier to install.
Old May 6, 2011 | 11:27 AM
switch
I have here the info from manufacturer, I am no electrician so I don't understand how to read the thing.
DC4442_07_24_08.PDF
I just try to duplicate what is existing.
Old May 6, 2011 | 11:44 AM
chaikwa's Avatar
Just order item # 8 from the parts list, part # 395-17, and wire it thru a four pole trailer connector from the trailer in to the truck. Easier, quicker and most likely as cost effective as jerry rigging something yourself.
Old May 6, 2011 | 11:57 AM
Talking
Here is the schem for the switch..
392 internal wiring.PDF
4 Wire Double Acting Wiring Cir 111.pdf
Thanks all for the quick replies,
Tim
Old May 6, 2011 | 01:13 PM
ddbackhoe's Avatar
Or, you could use a wireless setup
http://www.premium-supply.com/Products/WirelessRemote
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
Crimedog
Oct 14, 2004 07:19 AM
Math_Teacher
Apr 26, 2004 04:22 PM
DarrellB
Jul 11, 2003 09:37 PM
