Dana 80 Re-Build
Old Sep 15, 2009 | 08:06 AM
CTD NUT's Avatar
The carrier in the OP's truck could be either a Tlok or a Plok....the cover must be pulled to verify which one it is. You can't state that it is only a Tlok.
There is lots of different price point D80 kits....so, you have to be very specific when quoting a price like that. Clearly, you can get a Koyo master kit for under $200. You can spend more if you like.
D80 bearing and install kits
I can't find any firm pricing on a Plok clutch kit other than in the area of $150.
Tracloc clutch kit is $221
D80 Tracloc is $595
35 spline Trutrac is $581
If it is indeed a Tlok, I'm not at all surprised that it is loose at 150K....that is normal. A plok can go well beyond that since it uses variable clutch preloading that runs the clutches loose when not required and loads them much more than a fixed preload LSD (like a Tlok) when traction is required.
mrwaters
Dec 28, 2005 10:11 PM
Mechanos
Jan 22, 2004 12:45 PM
matthopp
Nov 21, 2003 04:49 PM
mcevins
Jul 3, 2003 02:06 AM
Stamey
Apr 18, 2003 10:34 PM
