Correct truck for towing
Looking to buy a 04.5 manual trans 3500 4x4 truck for towing horses, 80 percent driving at interstate speeds.
Which would be the best gear ratio, 4:10 or 3:73?
Originally posted by Grizzly_Bear_69
I just got back from picking up a '04.5 Quad Cab 4x4 DRW w/ 3.73 6-speed. I will be pulling a 15K 5er (I pick that up on Thursday).
I'll let you know how it goes...if you can wait a couple of days...
My .02. I pull a 4 horse gooseneck out here in the mtns. and on freeway. My 01 was 6 spd. w/ 3.54's and 295 BFG's. My 04.5 6 spd. is 3.73 w/ 315 BFG's. I never have a problem maintaining speed or power. I test drove a 04 w/ 4.10's before ordering my current truck and the rpm's at hwy speed were just too high. For your area, I'd recommend 3.73's w/ a 6 spd. and 4.10's if w/ an auto.
AUTO 4.10
6spd 3.73.
Unless you are towing 40,000 lbs. you don't need 4.10 with a 6spd.
according to rough calcs, in 6th gear at 2000 RPM youre about 68 MPH with 3.73 and 2200 RPM at 68 mph with 4.10s.
6spd 3.73.
From what I have seen, I prefer the 4.10's with the stick for towing heavy especially when operating at slow speeds or manuvering. The lower gear helps when reversing too. As far as towing 15-20k, auto or stick, if you had a choice I wouldn't even consider 3.73's - that is alot of weight. I'm not saying you can't do it with 3.73's, but at that weight, the more gear the better as far as I am concerned. All geared up, I am grossing 18,200 lbs and I sometimes think 4.10's would be nice (I only have 3.54's) but I spend most of my time empty.
Just my .02
Just my .02
