Checking RV battery???
Old Jan 4, 2008 | 09:27 PM
Roperteacher's Avatar
I was told to ck the water level in my battery on my trailer. It is a Centennial Deep cycle and there is a little clear window you can look down in. Seems like it has a green tinge to it but not sure... How do you ck the water in these things? THanks!
Old Jan 4, 2008 | 09:38 PM
02ramowner's Avatar
im not 100% positive but i believe if it has the sight window you are speaking of it is a sealed (maintenance free) battery, no way to check water.
Old Jan 5, 2008 | 10:32 AM
Jeff in TD's Avatar
Yeah, the little window is found on some AGM (Absorbed Glass Matt) that do not require water to be added.
It's still a good idea to wash up the battery and clean the posts and cables.
Old Jan 5, 2008 | 10:40 AM
Thanks so I will leave it alone!
Old Jan 5, 2008 | 02:07 PM
webbfoot's Avatar
If you have a meter check dc volts if it reads under 12volts no need to check water get new battery
Old Jan 6, 2008 | 06:41 PM
Bark's Avatar
If its sealed like our stock truck batteries its really difficult to get the lids off. Having always put water in batteries (even maint free) I just had to try opening one of mine. Its the one that looks like a monkey with an axe attacked it.
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
