Brake Control question
Old Aug 1, 2011 | 12:59 PM
steelblitzkrieg's Avatar
DTR Detective
All lights work, hazards/blinkers/running lights/brakes lights. But electric brakes no workie? My controller displays no trailer attached? Brand new controller (Tekonsha). Would a dead trailer battery cause this? Trailer has sat for a year.
Old Aug 1, 2011 | 05:52 PM
rickf's Avatar
Sounds like you have an open in either the blue or white brake wires. Make sure you have power to the controller. Have someone start wiggling the wires at different points while you watch for connection. Also plug and disconnect the trailer plug several times to make sure you have a good connection. Watch the controller while someone does this also. Check the ground where your trailer brake wire is grounded on the truck. Check with a voltmeter on the blue wire terminal for voltage as someone works the manual control.
The dead trailer battery will not cause this.
Rick
Old Aug 1, 2011 | 06:54 PM
DTR Detective
Thanks, I'll check it out when I get home and post my findings.
Old Aug 3, 2011 | 01:07 AM
Jeff in TD's Avatar
Taking an ohm meter reading between the trailer's neg and brake pins. That would at least tell you if the brake circuit on the trade is open, or if the problem is in the truck wiring or controller.
Old Aug 3, 2011 | 12:51 PM
DTR Detective
I have correct varying voltage off the brake pin of the truck side, so I'll ohm the trailer tonight.
Old Aug 3, 2011 | 01:11 PM
rebal's Avatar
could be bad magnets . might be a good time to inspect brakes on trailer and do a repack too
Old Aug 3, 2011 | 03:53 PM
Jeff in TD's Avatar
Yeah, ditto that if it sat for a year.
Was any work done on the trailer before it was parked?
Old Aug 3, 2011 | 04:15 PM
DTR Detective
No service, I used it last year without a controller, parked it at B-I-L's and it hasn't moved until I picked it up Sunday. I was initially getting intermittent lights, but I cleaned/greased the contacts and that went away. I'll ohm it tonight and post my findings.
Old Aug 3, 2011 | 04:51 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Just as a pointer, trailer wiring usually stinks. Check back at the wheels where the harness connects to the wheels. Make sure you have a ground too. They need a ground to be seen by the controller.
You might want to check all the trailer wiring for corrosion at thje connections.
Old Aug 3, 2011 | 04:58 PM
DTR Detective
Thanks, will do.
Old Aug 3, 2011 | 08:38 PM
DTR Detective
Okay, I have open line from Brake to what should be -, but I have ohms from Brake to what should be +
----------------Truck-------------Trailer
1 o'clock........+12v.................GRN
3 o'clock.........RH Stop............RED
5 o'clock.........Brakes.............WHITE
7 o'clock........-12v..................BLUE
9 o'clock........LH Stop.............BROWN or BLACK (16 gauge)
11 o.clock......Running............BLACK (12 gauge)
To me I'm thinking the Blue and White are reversed on the trailer.
Comments?
Old Aug 4, 2011 | 06:38 AM
olddodgetrucks's Avatar
If wired properly blue is brakes,white is ground.
Old Aug 4, 2011 | 07:27 AM
chaikwa's Avatar
Yes, but his trailer obviously isn't wired 'right'.
You should have ohms from the positive brake wire to the negative ground side, tho I can't tell you what the ohms should be. The power is going thru magnets, thus the ohms.
Trace that white brake wire and I'll bet you'll find either a bad connection or a broken wire. If not, check the ground wires coming from the brakes. They DO need their own ground. Tying into the frame to achieve a brake ground just don't work!
Old Aug 4, 2011 | 07:51 AM
ddbackhoe's Avatar
Depending on which way you're calling o'clocks, 5 and 7 may be reversed, which may only matter if the brake ground is on the frame. Hopefully, you'll find this link helpful.
http://www.etrailer.com/faq-wiring.aspx
Old Aug 4, 2011 | 09:17 AM
I guess i dident think some people would have a hard time swiching or tracing a few wires.
