Biggest Tag Trailer
Old Jun 13, 2004 | 03:50 PM
RAMV's Avatar
Biggest Tag Trailer
WHo has towed a long/large bumper pull style trailer? Thinking like 12-15k on a 30-40' trailer? Behind a 2500? Thoughts, concerns other? Obviously need WD hitch and Class V rating, but what else, huge pain or just not as good as a goose or fiver?
Some trailer shops said DRW only, but I see large travel trailers that must be 12 k plus all the time......
Thanks
Old Jun 13, 2004 | 09:40 PM
Barry Smith's Avatar
I'd say it would be a pain. It would wonder all over the place. Go with a GN. Alot more stable.
Old Jun 13, 2004 | 11:41 PM
jigdog's Avatar
12-15k could be done i would think you would want a class v hitch at least or maybe a superhitch i don't know what they are rated for. i think that dc recomends only 10k on their frame but you could beef that up some.if you went with air bags on the suspension,wd setup and anti sway bars, maybe two you could do it. The main problem with long bumper pull trailers is the sway thats caused by alot of trailer that over hangs behind the axles. it gets going back and forth. i tow a 02 terry 30 ft with tandem axles and the full wd setup. I would not want to tow anything longer in this configuration.
Old Jun 15, 2004 | 08:03 PM
pop99's Avatar
I made a 33' bumper pull out of a travel trailer frame. We used it to haul 2 race cars to the track on Saturday nights. There was also a big tool box and tire rack mounted on it. I didn't last long with this rig. I went real quickly to a 36' gn. It handles much better with no sway.
Old Jun 16, 2004 | 04:14 PM
induchman's Avatar
There's someone over on the Woodalls rv forum with a 41ft travel trailer.
Old Jun 16, 2004 | 09:10 PM
tp4whlr's Avatar
I've been pulling a 31' terry with a 99 PWRSTRK with no issues.
I just traded the ford for 04.5 Dodge 2500 CTD, I haven't had a chance to pull yet, but I'm hoping for the same or better.
Ted
Old Jun 17, 2004 | 10:51 AM
Dufrain's Avatar
my 34 ft airstream only weighs about 8000 empty.When I brought it home with my old 76 chevy dually with no equalizer bars or sway bars it didnt sway around a bit.it has 3 axles under it.I had dualls but no bars so maybe if you get the equalizer bars and sway control bar yours will be fine.Im pulling it to florida in a couple months with my single wheel truck.
Old Jun 20, 2004 | 10:04 PM
dalee's Avatar
I pull a 32ft 12000lb trailer and a 10ft hard side truck mount camper 98 12v 3.54 auto and love it. I use 2 sway controls and equilizer bars
Old Jun 21, 2004 | 06:18 PM
diirk's Avatar
I have a 30' Toy Hauler. Dry weight is 7600# w/ no options. Loaded, I'm easliy pulling at least 12k. I do have a Titan (modified) and associated WD. I'm currently using a single friction sway control. Overall, it wasn't bad. I ran it over the Grapevine and across the 166. So a combination of hwy and hills with some nice curvey roads. Pretty smooth acroos the board with minimal sway. Even after I lost a clip the disabled my sway control, it still ran decent, I jsut had to slow down to legal speeds. Running the Grapevine I ended up throwing it in 2nd but easily maintained speed up the hill. I am going to upgrade to a dual cam sway control, but that is more a matter of comfort than necessity.
Old Jun 22, 2004 | 04:16 PM
Tommy93w350's Avatar
I pulled a 40' travel trailer that I bought home about 20 miles with a single wheel ton truck. It wasn't bad for the short distance. I t could be dangerour on the interstate with trucks passing.
I regularly pull a 35' Cedar Creek TT with a 3' carry-all on back for extra storage, it weighs a little over 10,000lbs with a 01 subarban w/8.1 liter. I use a dual cam sway bar/distrubution hitch, no problems. Several 500 mile trips to beach and up the Appalacian Mountain.
Old Jun 22, 2004 | 07:26 PM
jw99352's Avatar
I tow a 34 foot toy hauler..about 9K loaded. I have Rancho 9000x and airbags. Tows great, have towed it about 20K miles in the last 18 months throughout the southwest.
Old Jun 23, 2004 | 07:34 AM
WA4SLC's Avatar
I tow a 33 Ft. Sprinter 300 FKMS TT. The dry weight on is 8100 Lbs. and the GVWR is 11000 Lbs with a 1080 hitch weight. I do not know the exact weight of it the way I pull it down the road. That is on my to do list, stop at a truck stop with the CAT scales and weigh every thing.
I puled this trailer with my 01 2500 which had a 9850 Lbs. weight rating. I have the Reese dual cam anti sway system and the load distrubition hitch with 1000 Lbs. bars. Even though the truck was at its maxium tow limit it did not have any trouble pulling the trailer. I do not experience any problems with sway. The secret is to take the Reese instructions and go to a level parking lot and set up the hitch right and maintain the proper air pressure in the tires.
I just traded for a 04 2500 with the 325/600 Cummins. I am hoping it will do even better with my TT. Its tow rating is 13000 Lbs. One thing that concerns me is the wimpy looking hitch recever on the new trucks. There is nothing on the hitch that says what the weight rating is. Everything I have read and have been told says it is rated at 12000 Lbs and 1200 Lbs. weight. I hope they are right. It just does not look that strong to me. I will find out in a couple of weeks, I am pulling it on a 635 mile trip to Alabama.
Old Jun 23, 2004 | 06:43 PM
fire1355rescue's Avatar
My dozer trailer used to be a bumper pull and i haul a case 550 long track (not real sure on the weight, but its heavy) on a stock reciever hitch...so what they will take i have no idea, and for that manner i really dont wanna find out!!!
Rednecktastic
Feb 19, 2012 08:27 AM
91rangerturbo
Sep 11, 2008 08:38 AM
Ripper406
Sep 11, 2005 07:59 PM
MNYPDRBLT
Apr 1, 2005 11:53 AM
Commatoze
Aug 7, 2003 08:04 AM
