Another Question On Water Heater
Old Sep 25, 2005 | 05:59 PM
deezulsmoke's Avatar
Is is a good idea to keep an anode in your water heater thru out the year until you winterize your system ??
Old Sep 25, 2005 | 07:22 PM
FiverBob's Avatar
I assume you mean the sacrificial anode, right? Absolutely keep it in there. Most people pull that anode to drain for winter and leave it out until the spring. But, be sure to put it back in the spring - - it reduces the deterioration on the tank by sacrificing itself. I replace mine about every year for a new one even though I don't have to winterize (thanks Florida) - - cheap insurance.
Bob
Old Sep 26, 2005 | 01:47 PM
the real FYRMAN's Avatar
Suburban water heaters are a steel tank, and have the anode rod built into the drain plug. The anode rod needs to be used. Atwood water heaters are an aluminum tank that is lined with glass. You do not need to use an anode rod.
Old Sep 27, 2005 | 10:43 AM
Thanks guys !!
12valve@heart
Oct 25, 2008 09:02 AM
LanceD
Jul 15, 2007 02:33 PM
Jezzhuntin
Aug 25, 2006 02:51 PM
deezulsmoke
Sep 25, 2005 07:26 PM
