air bags and toss the contact overloads?
It seems like a set of airbags would provide way more load capacity than I need so is it reasonable to ditch the overloads when adding airbags?
I'm fine for weight now but will be close to the load limit when I add a 50 gallon fuel tank. FIgure the ride might be better w/o the extra spring leafs too.
Are you're talking about the rubber stops which are attached to the frame and will make contact with the axle when overloaded? At least with the Firestone Air bags that I installed on my 2006 2500 those overrides are removed as part of the install process.
On 3rd gen's only 3500's have overloads.
Treangen
Mar 8, 2010 06:13 PM
steelblitzkrieg
Jan 21, 2008 11:07 AM
