5th wheel hitch
Old Apr 16, 2008 | 04:00 PM
SundayMoney's Avatar
Originally Posted by blownsmoke
I stand corrected. However, the clamp on is real easy and the holes for the outter brackets are already in the frame. There is even hole in the hat section of the box but you still have to drill from the top down.
My Pullrite uses a bracket that requires no drilling. Its a simple bolt on install.
Works well.
Old Apr 16, 2008 | 05:50 PM
imbodie's Avatar
Ok....
now I'm worried for other reasons.... my truck has a gooseneck ball that was installed when I got the truck... it's on a plate and bolted THROUGH the frame.... is there something I should be watching for because it's bolted?
-Tim
Old Apr 16, 2008 | 08:48 PM
Thundercraft's Avatar
Originally Posted by imbodie
Ok....
-Tim
Correct me if I'm wrong, but the no drill applied to the 3rd gens (before the TSB came out)? 1st & 2nd gens were OK?
Old Apr 16, 2008 | 09:03 PM
Busboy's Avatar
There must be hundreds of thousands of 1st and 2nd gen trucks with bolted 5th wheel hitches. Mines bolted and its been there since new. Personally if you can't DRILL a half inch hole in the side of the frame away from the radius I don't think I want the truck.
May 14, 2010 05:06 PM
buck358
Jul 5, 2003 09:17 AM
TommysBlue
Jun 4, 2003 09:57 AM
kamper
Mar 29, 2003 10:13 PM
moss2904
Oct 29, 2002 08:27 PM
