? on a 340hp Cummings
Old Apr 24, 2012 | 07:59 AM
jpajax's Avatar
I have a 2009 motor home with a HP Cummins and a 2100 ally 6 speed trany. The ? is what can I do to up the torque and can I delete the erg with out it going into limp mod.?
Old May 7, 2012 | 10:38 AM
dieselfreak21's Avatar
For a power upgrade I'm sure someone has a programer available for the motor or you might check with cummins to see if they have ECM flash for more power. As for the EGR, my guess is you can't remove it with out codes and it going into limp mode. I'm not sure if there is a programer our there to turn it off in the ECM. Also you need to check the specs on the tranny to see if it will safely handle a power upgrade. If not you may need to look into upgrades to it as well if available.
Old May 7, 2012 | 12:13 PM
Tedonlin150's Avatar
Which Model is the engine? ISB, ISC, ISL?
Old Sep 9, 2013 | 09:49 PM
jpajax's Avatar
It is a ISB I am looking more towards EGR removal if it will not cause any damage.
Jambbii
Dec 21, 2004 09:43 AM
DieselMatt
24
Jul 18, 2004 09:51 PM
sway825
Jan 12, 2004 02:11 PM
98rammer
Aug 11, 2003 12:46 PM
Hoss
Feb 25, 2003 09:24 PM
