2nd Gen. Mopar tow mirrors
#46
Mechanos,
Probably a dumb question, but in your post about the 3rd. gen mirrors having five wires, two of them being black and used for the heated option. What did you ground the other wire too. Was it just to the inside of the door close to the plug in or does it really matter where it's grounded.
My truck has the power heated mirrors so I have that going for me anyway. I am in the process of ordering both sets of mirrors and will be starting on my project when they show up.
#47
Howdy,I am starting to convert the 02 mirrors to the 04.What do yuo guys use to pry the teeth out and do you keep going around and around until the spring pops out.Thanks for any info.
#49
Originally posted by d0dg301
Mechanos,
Mechanos,
#50
I then reset the teeth on the retainer to the proper angle with a punch prior to reassembling the mirror/base.
#51
Originally posted by Forrest Nearing
why convert to power? if I had flip outs, they'd always be flipped out!! they look so sweet standing tall!
#52
With a dually they should always be flipped out. The old rule with the big truck is if the mirror clears, the rest will. Keeps the fenders from getting trashed.
#53
Originally posted by Mechanos
Because when they're flipped out.... they are way out there. You'd have to get out and walk over to the drive up window and the burger joints.
#54
don't they pull in?
don't they pull in?
#55
Mechanos,thanks for the info,I did all four retainers (Remove) in about 30 min.I could not tell anybody an easy way to do it exept stay out of the way!!Mirrors work great .Definately worth the money and hassle...Popeye
#56
here are the connector pin-outs for the 3rd. gen. tow mirrors
POWER MIRROR LEFT
1-heated mirror relay output
2-left mirror common driver (right/down)
3-left mirror left driver
4-left mirror up driver
5-ground
POWER MIRROR RIGHT
3-right mirror left driver
4-right mirror up driver
5-ground
POWER MIRROR LEFT
5-ground
POWER MIRROR RIGHT
5-ground
#57
well i finished my swap last night.it went fairly easy.
thanks to everyone for thier answers to my questions.if someone would like a set of manual tow mirrors for the 3rd gen.trucks,i listed mine in the classifieds.
thanks again,
mike
thanks again,
mike
#58
pin connectors for 2nd & 3rd gen tow mirrors
I posted a pic in my photo gallery of the pin connectors for the 2nd and 3rd gen. tow mirrors. This should take the guess work out of the wiring of the plug ins.
I've got both sets of mirrors on order and I'm going to the dealer to see if I can order another factory plug for the 2nd gen. mirror so I won't have to cut the one off of my stock mirrors.
BRUISER
02-02-2015 11:25 AM
casper_cobra
04-14-2006 11:32 AM
