Tone Ring Help
Old Apr 14, 2009 | 01:01 PM
cincydiesel's Avatar
Tone Ring Help
I have a broken tooth on the tone ring that keeps throwing a P-0036 code. How hard are these to replace????
Old Apr 14, 2009 | 01:12 PM
Mexstan's Avatar
You mean the one bolted to the front of the crankshaft? If so and presuming it is the same as the 2003's, then it is a short, easy, 4 bolt job.
Suggest doing the tone ring mod before installing the new one.
How on earth did you manage to break a tooth off?
Old Apr 14, 2009 | 01:22 PM
I dropped a 1/2 rachet down the engine compartment while changing my fuel filter.. Dealer wants $296 to replace. I sure could use the money towards other things right now.. I would assume that I need to remove the serpantine belt and crank pulley to access?
Old Apr 14, 2009 | 02:02 PM
Dodgezilla's Avatar
I think on an 05 you will also have to unbolt the bottom radiator shroud bolt to get better access to the dampner bolts. I had to use a 3lb hammer to loosen the bolts on my 03 to do the tone ring mod. I also used the hammer to "Torque" them back down...
And yes, you have to pull the dampner off and then the tone ring comes right off. Do not take the serp belt off first. You will need that tension to help break the bolts loose. Pull the belt off once you have the bolts loosened...
Old Apr 14, 2009 | 02:07 PM
Thanks guys!!! Seems simple enough
Old Apr 14, 2009 | 07:17 PM
Mexstan's Avatar
Why can't you pull the ring off, build up a new tooth by welding and then file it down to size? That way you will save $296. As a bonus do the tone ring mod and gain a few free horses.
Old Apr 14, 2009 | 07:30 PM
I couldn't use a welder if someone held a gun to my head.. Now if it was made of wood thats another story.
Old Apr 15, 2009 | 04:09 AM
Dodgezilla's Avatar
Use some JB Weld......
There is a salvage company that advertises on another site. He just parted out a couple 3rd gen Dodge CTDs. PM me if you want his info. I would bet he has one for a lot cheaper than new......
Old Apr 15, 2009 | 06:05 AM
m21221's Avatar
As mentioned before remove the lower fan shroud nuts/bolts... it it much more flexible than it looks and you can push it up and out of the way to give you easy access.
Old Apr 15, 2009 | 06:54 AM
Dodgezilla's Avatar
I took the liberty of sending him a message to see if he has one available for you...
Your welcome......
Old Apr 15, 2009 | 08:06 AM
Your welcome......
Thanks you sir... However I already bought one from the dealer it should be here on Friday. only $95.00 (I got it from another dealer)
Old Apr 15, 2009 | 08:47 AM
Dodgezilla's Avatar
No problem. Isn't it amazing how much difference there is in price from one dealer to the next?
Old Apr 15, 2009 | 10:05 AM
Its sickning!!! The parts guy actually told me he works off commision
Old Apr 15, 2009 | 10:14 AM
bluepp's Avatar
On a 06 with a 48re trans, is it possible or feasable to do the tone ring mod along with the sencer mod?? I understand the sencer mod advances timming about 2*. If the tone ring is moded too would that advance the timming too much??
Old Apr 15, 2009 | 10:20 AM
Do you have anything else to advance timming like a programmer?
If not I would think you'd be fine.. I know some programmers advance timing by 5*
