search function
search function
I read the post about my search overloading the system and i should refine my search wordage, but "fuel pump issues" I think is pretty refined. I get this error message.....
Fatal error: Allowed memory size of 50331648 bytes exhausted (tried to allocate 35 bytes) in /opt/www/html/dev/search.php on line 1028
Way too broad for the following reason. All generations of these trucks have had fuel pump issues. That means the search engine is looking at all the entries on the forum. What specifically are you looking for and with which generation truck?
Also, I have noticed that if you do a search as "fuel pump issues", you will get hits from every post that contains any of those three words. This would definitely overload the server as 50% of the posts on this site probably contain one of those three words.
It seems to work better if you do the search as "fuel+pump+issues", as the plus sign will create hits only on posts that contain all three words.
Alternately, you could put the search phrase in quotation marks, and it would only create hits on posts that contain the whole phrase "fuel pump issues".
atch
Nov 1, 2010 02:45 PM
suzukiZrider
Jan 18, 2005 06:56 AM
das280zx
Dec 30, 2003 09:36 PM
