Wiring a relay for Holley Blue
Old Mar 3, 2007 | 05:33 PM
AllonBlack's Avatar
Holley Blue install will be this weekend, and wiring is not exactly my thing. I have been doing some research and it looks like I will need a 30 amp relay. So is this what it should look like?
30 is the positive of the battery (on a 20 amp fuse)
87 is the positive to the pump
87a is the ground
85 is connected to the ground of the triggering voltage.
86 is connected to the positive 12V of the triggering voltage.
Also, what should I use for the triggering voltage? Is it best to use the stock LP wires?
Old Mar 3, 2007 | 08:49 PM
Mike D's Avatar
Looks right, but I'm going off memory so take it with a grain of salt. Using the lift pump wire as a trigger for the relay is just fine to do. Works great.
Old Mar 4, 2007 | 12:49 PM
AllonBlack's Avatar
anybody else?
Old Mar 4, 2007 | 12:52 PM
scottsjeeprolet's Avatar
Same as above, i trigger my Holley relay off the stock LP hot.
AlCorr
114
Feb 11, 2009 02:32 AM
kyncl
16
Nov 18, 2008 04:48 PM
Texaschevelle
26
Nov 16, 2007 08:08 PM
Tiger Rag
Mar 7, 2006 06:56 PM
greenwing
Feb 23, 2006 09:36 AM
