wire tap?
Old Jan 6, 2008 | 04:52 PM
2001 CTD's Avatar
wire tap?
i hear people tapping there edge juice what does that mean and how do u do it and does it help? and also with that turnbuckle mod how long of a turn buckle should i buy. is there a benefit with the turnbuckle over the J hook?
Old Jan 6, 2008 | 05:02 PM
hink's Avatar
You have to tap into the wire going to the VP44 to get the full fueling from the Juice/Att. set-up.
With a tunbuckle, you get NO adjustment at all on the wastegate. With a J-hook, you can adjust it to regulate pressure.
Old Jan 6, 2008 | 05:03 PM
hink's Avatar
BTW, I would think that there would be instructions included with ur Juice/Att. to show you how to tap the pump wire.
Old Jan 6, 2008 | 08:20 PM
91rangerturbo's Avatar
solder the connections instead of wire tapping with a scotch lock connector. And use liquid electrical tape to seal it up when your done. Trust me on that one.
Old Jan 7, 2008 | 02:12 AM
1BAD4X4's Avatar
Its not really hard to do, but it can be difficult to find the correct wire to tap if you've never dug into the VP44 at all.
The turnbuckle is cheap but the J-hook is safer in the way it lets you build more boost but doesn't build boost past the stock turbo's efficiency range.
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
TPilaske
16
Nov 22, 2002 08:15 PM
