Will this hand throttle work?
Old Nov 25, 2003 | 12:09 PM
95ramtough's Avatar
It has been getting really cold and I want to install a hand throttle. This one mounts on the stick, would this work in my 98 12 valve?
http://www.rubiconexpress.com/dynami...p?folderid=785
Old Nov 25, 2003 | 03:42 PM
Smokee's Avatar
Re:Will this hand throttle work?
Sure, that should work. You can go to any tractor supply store and get a throttle cable pretty cheap. I installed a cable to the fuel pedal linkage using a bead chain to give slack. Worked great, and I didn't have to go through the firewall.
Old Nov 25, 2003 | 04:23 PM
95ramtough's Avatar
What do you mean by bead chain? So you could mount a thumb throttle on the stick then run the cable to the gas petal?
Old Nov 27, 2003 | 03:01 PM
Smokee's Avatar
Yes. Fasten the bead chain to the linkage with enough slack so that the linkage can move, but when you pull the throttle cable, you are able to overcome the slack and pull the linkage.
It is simpler to understand if you look at the linkage at the pedal.
Old Dec 10, 2003 | 09:59 PM
peanut's Avatar
Someone enlighten me o n this subject.............Im from Texas where it doesnt get real cold. Im tryin to figure out the advantages of a hand throttle.
u add it on and can still use the pedal?
lol...maybe im dumb :
Old Dec 11, 2003 | 09:04 AM
Olratlr's Avatar
Are you can go to about any Big Truck Stop and
get a adjustable throttle stick for about $8.00.
Old Dec 12, 2003 | 10:03 AM
Zino's Avatar
Its for a high idle to keep the truck warm when its really cold out.
darrenG
Oct 5, 2005 11:12 PM
Hounddog
Jan 19, 2005 09:16 AM
peanut
Jan 6, 2004 09:46 PM
DieselDaze
0
Dec 11, 2003 11:45 AM
