will eng. go in with oil pan installed?? ok its been all day..getting board..
Old Oct 3, 2003 | 09:55 AM
thumper 549's Avatar
not sure where to post this, but i figure this place pulls out and installs engs. more often then the board upstairs.
now to the pt. when i pulled my isb out ,it had the oil pan off. i recall being real close to the front axle (4wd). but most of my focus was on finding what the noise was and had been pulling off so many parts in elimination of noise (suspects)that i do not know for shure if it will go back in with pan on or if it has to be off????
just tring to save a gasket time and $$ i know the valve cover will be off ,and that gives a little more room. :-
thanx in advance evven
Old Oct 3, 2003 | 11:33 AM
banshee's Avatar
Re:will eng. go in with oil pan installed??
I didn't think you could get the oil pan off with the engine in the truck. ??? I thought the pan had to be on when putting the engine in.
Old Oct 3, 2003 | 11:40 AM
Mexstan's Avatar
Hey thumper, presume if you are asking this question that the engine is now assembled and ready to drop back in. If so, great news.
Sorry, can't answer your question.
Question for you. Before dropping the crankshaft in did you rod out all the oil passages and then use compressed air to blow them out? Also are you triple sure that ALL the bearing shell oil holes line up with the oil holes in the block?
Old Oct 3, 2003 | 12:14 PM
yes and all that and some more..have .020 deck ht. and recon cummins head as mine was to cracked to do anything with..!
hope fully this weekend the eng. will at least sitting where it ought to be 8)
thanx for the input-been hot tanked so many times its got wrinkles
ps ..Banshee oh yea the oil pan comes off in truck real ez just lift up the eng . a little
Old Oct 3, 2003 | 01:39 PM
banshee's Avatar
Thumper,
gotcha. I'm pretty sure it won't come off with the engine bolted in (hence the danger during cam changes), but jacking it up a little makes sense.
John
Old Oct 3, 2003 | 03:05 PM
i do remember pulling the pan off it was a pc of cake, and fishing the oil pick up tube out was no problem, maybe on 4 wd this is all ez r ,i am just tring not to out guess myself here i would like to drop the whole thing in complete w.o. going backwards :-
stage left evvven
Old Oct 3, 2003 | 05:26 PM
Diesel-Dan's Avatar
Maybe your should put a call into Mag-Hytech and get an EXTRA deep oil pan made up custom for ya there pardner! Could start a new trend! Let us know how it fits and if the fnt axle clears! ;D
NoSparkplugs
Aug 19, 2011 07:46 PM
John Faughn
May 25, 2008 11:05 AM
Hayseed
Feb 13, 2007 11:00 AM
bostongsx
Sep 25, 2006 11:25 PM
cowboy27
Nov 15, 2005 06:54 AM
