Who has a two low kit ????
Old Oct 25, 2006 | 10:07 PM
caper's Avatar
Looking to install a kit on my 97 for backing up trailer , is there a cheap kit or can you make one yourself , how hard is the install ???? Thanks
Old Oct 25, 2006 | 11:14 PM
SWC's Avatar
SWC
caper, I have the BD 2 lo kit on my 01.5. It is a very easy install. I installed it over 3 years ago. The price was quite reasonable I thought. The shifting valve is the same as on my pacbrake.
Hope this helps.
Stan
Old Oct 26, 2006 | 03:13 PM
JKM's Avatar
JKM
Make your own if you want to , go to Princess auto , or any other place that sells air valves , get a solonoid operated one , normally open , and splice it into the vaccum supply line going to the switch ontop of your T case, mount a switch in the cab for the solonoid. Flip the switch to energize the solonoid , and close the valve , then shift into 4 low. The solonoid valve will prevent the vaccum from sliding the locking collar on your axle , and with the t case in 4 low , you will still only be in 2wd.
Old Oct 26, 2006 | 05:05 PM
cummnz4x4pwr's Avatar
4x4 posi-lok system works great and you dont have to worry about the vacuum actuator going south, or getting a hole in a line on you either.
Jake
Old Oct 26, 2006 | 05:45 PM
Tiger Rag's Avatar
The BD kit is under or around a hundred bucks. It should be easy to install as all BD stuff has thorough directions. I'm going to do one myself, just haven't gotten around to it yet what with hunting season and all. Looks like a winter project....they are mounting up at this point....
Old Oct 26, 2006 | 05:59 PM
Big Smoky's Avatar
Hey caper, if I'm not mistaken the '02 dosen't have a vaccum actuated locking axle. On my '02 there is nothing on the axle where the fork should be. The axle is always locked. I know because the driveshaft is always spining. It's the T-case that unlocks and thats it. This is how it is on every '02 I've seen. So I really don't think you can do it. Correct me if I'm wrong.
Eric
Old Oct 26, 2006 | 06:00 PM
Big Smoky's Avatar
Never mind. I didn't see that you said for your '97. I was just looking at the signiture. Sorry!
Totallyrad
May 23, 2010 12:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
ken-c
Feb 25, 2005 10:08 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
