wheel compatability 95' - 08'
Old Oct 23, 2009 | 09:00 AM
paidoffpit's Avatar
My 95 wheels are old and crusty. I found a set of factory 2008 8 lug on craigslist, $250, they look sweet. Does anyone know whether they'll fit on my 95 8 lug? I know there are variances of offset and hub diameter, etc...
Old Oct 23, 2009 | 03:52 PM
Beast2B's Avatar
we put a set of 08 aluminum stockers on a 96 2wd and they fit fine. worked great til the idiot in the minivan tagged the right rear wheel and sent the truck skidding over a steel storm drain! tore the frame at the lower a-arm mounts...
the only issue i know of is putting older wheels on newer trucks-- the newer (03+) trucks need 17" or bigger to clear the brakes.
Old Oct 26, 2009 | 03:01 PM
01trailerpuller's Avatar
The lug pattern on a Dodge and Chevy have not changed since 88. They are interchangeable from then tilt now. The only factor is brake size like "Beast2B" said. Ford changed to metric in 99, but from 88-98 they will fit on a Dodge or a Chevy or vice versa. By the way that is a great deal, I want a set for my truck but have not seen a set for less than $500.
Old Oct 26, 2009 | 03:52 PM
PaulDaisy's Avatar
I am interested in this too. I have read that some wheels don't clear the rear drums on pre 2001.5 trucks? Could someone say if 2004 17" steel wheels would clear the drums?
Old Oct 26, 2009 | 07:19 PM
I don't think it should be a problem if a 16" fits on it.
Old Oct 27, 2009 | 02:42 PM
PaulDaisy's Avatar
The only thing might be, the 16" at 6.5" are narrower than the 17" at 8". Would be nice to know, I wouldn't want to machine the drums.
Ian
Dec 4, 2005 05:25 PM
caleb c.
Dec 21, 2004 04:04 PM
Jmac
21
Nov 10, 2004 12:41 PM
donboisjoli
Oct 10, 2004 07:06 PM
CruisingRam
May 24, 2004 02:11 PM
