Whats the best way to?
Old May 12, 2004 | 04:17 PM
Mslaughter's Avatar
Whats the best way to get smoke out of a 12v safely? All I plan on doing is straight pipe, filter, timing, and injectors probably remove the plate too. What is a good, safe size injectors for smoke? Also is there another way to get smoke safely? And what is a silencer ring I keep hearing about? Thanks a lot
Matt
Old May 12, 2004 | 04:56 PM
BigBlue's Avatar
A new fuel plate, bigger injectors, straight pipe, air filter, and timing. That should give you the smoke your looking for. You can also adjust the star wheel. That should give you smoke.
Old May 12, 2004 | 05:09 PM
Mslaughter's Avatar
With those mods how would my auto tranny hold up? Or, should I do the mods to my 5 spd work truck if it will hold up better? Also whats a safe size of injectors that will give me a good amount of smoke?
Old May 12, 2004 | 05:33 PM
Lil Dog's Avatar
Do you want smoke or power?
Old May 12, 2004 | 05:34 PM
DRD's Avatar
DRD
Why do you want smoke??
Old May 12, 2004 | 05:37 PM
Mslaughter's Avatar
Want mostly smoke don't really need a lot of power. I love seeing smoke pouring out.
Old May 12, 2004 | 05:43 PM
Rattletrap1's Avatar
Must be what it means by "junior" member. Sorry...couldn't resist.
Just put a smoke bomb in the tailpipe.
Old May 12, 2004 | 06:11 PM
DZLPWR's Avatar
OK if you just want smoke, loosen the four bolts on the afc housing, slide it all the way forward. Turn the star wheel towards the engine untill it stops. You should have plenty of free smoke then.
Old May 12, 2004 | 06:16 PM
HOHN's Avatar
not to mention a melted turbo
Old May 12, 2004 | 06:35 PM
DRD's Avatar
DRD
I had lot's of smoke when I blew one of my lower intercooler boots off, if that helps
Old May 12, 2004 | 07:02 PM
cumminsdriver635's Avatar
My 94 dodges Torque Converter slips with just a plate, so I wouldnt reccomend more than that on a stock auto. It smokes really good though in my opinion, but only if you have the TC locked up. It doesent smoke much without the TC locked up.
Eric
Old May 12, 2004 | 11:16 PM
Mslaughter's Avatar
I think I'm gonna try DZLPWR's advice first and see how much I can get then. It seems kind of pointless to spend a lot of money on injectors/plates etc. when I have no use for all the extra power.
Old May 13, 2004 | 10:32 PM
dsljunkie's Avatar
You may want to get some gauges to see what that SMOKE is doing to your egts . I wouldnt recomend fully removing the plate , too many horor stories. You could simply slide it forward and cut your AFC spring in half. That will give you PLENTY of smoke .
Scott
Old May 14, 2004 | 12:01 AM
Tackett's Avatar
When I want to smoke...
I hook up a trailer, head to high elevation on a hot day and turn on the A/C.
Once I'm in the high desert in the summer with a trailer, I can blot out the sun if I give it lots of skinny pedal (but not so much as to force a downshift).
Old May 14, 2004 | 11:08 AM
MCummings's Avatar
What year 12V? Som esmoke alot more than others. There are many HP ratings of the 12V motor. From 145HP to 215.
To get smoke when starting off, Lossen the AFC housing spring.
It's an allen head plug on top, and towards the rear of the pump. Unscrew the allen plug (it wil be seated tightly) and just take a small head screwdriver, and click the "star wheel" towards the motor a ton of clicks (about 20+), or untill the spring looses it's tension. Tighten the plug back up, then get into the truck, start it, put it in gear, now ROMP on the fuel for a couple seconds (Just go WOT) and you should get a fair sized puff.
Adjusting the AFC ONLY will give you better response, and minimal HP.
Merrick
Tuf-4x4
13
Apr 27, 2008 11:56 AM
Ghost Ram
Jul 26, 2007 10:12 PM
kawi600
Jun 22, 2007 06:45 AM
eodshawn
Jun 1, 2007 10:19 AM
Earthmover627
Aug 21, 2006 06:50 PM
